Soeks Quantum
7 years 6 days ago #4725 by mattia
Soeks Quantum was created by mattia
Hi guys,
Today after one month is arrived my brand news Soeks Quantum. Anybody has the parameter to setup Radlog Professional?
Thank you so much.
p.s. I wait two or three days and then I made a review of the product.
Mattia
7 years 5 days ago #4739 by mw0uzo
Replied by mw0uzo on topic Soeks Quantum
Hi Mattia
Welcome to radmon.org!
First thing to do is see if we can get a serial stream of CPM data from the counter when it's plugged into your PC.
Have a look through the manual. Is there any mention of connecting to a PC and serial device baudrate. Do any devices come up in Device Manager when you plug it in?
7 years 5 days ago #4742 by mattia
Replied by mattia on topic Soeks Quantum
Hi my friend. The device has a program and a specific driver to download realtime the measure. When I check the com port, I see that the bauds are 9600. I've tried to set this parameter on radmon but I've not response. :unsure:
With his program the device work perfectly in windows and in mac system.
7 years 5 days ago #4743 by mw0uzo
Ok, next you need to use a serial terminal program (RealTerm?) to see what information is being sent over the COM port. Use default port settings and 9600 baud rate.
Usually, the CPM is sent every 30s or so, as a number.
We need to check that the data sent is in the format expected.
When you get some data to appear in the terminal from the calculator, cut and paste it here.
7 years 5 days ago #4746 by Simomax
Replied by Simomax on topic Soeks Quantum
This is the manual for the Soeks Quantum (English about half way through)
https://drive.google.com/file/d/1KrVLxHPyz0uJj0xt4j4KL1Sb_lFKfC-J/view
I have had a look but it states nothing about CPM or other real time live output. Also everything in the manual is stated as uSv with no mention of CPM. It does mention not to connect the USB whilst there are non-rechargeable or no batteries installed. Would be best to fit rechargeables if connecting to a computer or external USB PSU.
7 years 5 days ago - 7 years 5 days ago #4748 by mattia
The instruments has his rechargeables batteries, connected via usb cable and has cpm, uSv and mR. :)
Last edit: 7 years 5 days ago by mattia.
Time to create page: 0.157 seconds
Solar powered Raspberry Pi 4 server stats: CPU 59% Memory 15% Swap 17% CPU temp=63.3'C Uptime 17 Days
