Python3 support for Pyradmon
3 years 10 months ago #6253 by RadiumUser
hi to everyone,
i'm new here, and to start submit CPM to radmon.org webservice with raspberry, i had to modify the source of Pyradmon.py to comply the new Python3.x sintax standard.
I hope it can help someone else.
i'm currently use Raspberry3A+ with Raspbian x64 minimal installation.
this attached file is the no sound version of Pyradmon on github.
File Attachment:
File Name: Py3Radmon.py
File Size:25 KB
greetings,
Bg
The following user(s) said Thank You: mw0uzo, Simomax, docsquee
3 years 10 months ago #6254 by oz1ewr
Replied by oz1ewr on topic Python3 support for Pyradmon
It WORKS right out of the box.
Thank you many times.
Regards Erik Nielsen, OZ1EWR
The following user(s) said Thank You: RadiumUser
3 years 10 months ago #6255 by mw0uzo
Replied by mw0uzo on topic Python3 support for Pyradmon
Well done RadiumUser! PINNED!
3 years 9 months ago #6290 by n2uem
Replied by n2uem on topic Python3 support for Pyradmon
Thank you so much for doing this; however, I cannot get it to work with my setup. I was hoping you might have some advice. I am running an RH Electronics MyGeiger 2.0 and a Pi 400 running bullseye. When I run  Py3Radmon.py  I get the following error:
Problem in getData procedure (disconnected USB device?) => geiger 1; can only concatenate str ("not bites") to str
thoughts?
thanks
-Mark
2 years 5 months ago #6913 by docsquee
Thanks for this!
1 year 10 months ago - 1 year 10 months ago #7051 by jnissen
This came in very handy as I recently upgraded my Raspberry Pi and installed the latest Software. I could have gone back to Python2 but there were only about 5-6 lines of code. Working again.
Thanks for the conversion as I am using a custom version that was hand timed to work with my older GMC detector. I really didn't want to go back and edit all the sections to alter delays and such.
Last edit: 1 year 10 months ago by jnissen.
Time to create page: 0.222 seconds
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 13% Swap 18% CPU temp=62.8'C Uptime 17 Days
