Disconnected USB device? problem
10 years 4 months ago - 10 years 4 months ago #2083 by James_Gy
I've been having a few problems recently with the PyRadmon stopping sending data so I tried doing a complete reinstall but I'm having problems. After setting everything up (as I have done many times in the past with no problems) and running PyRadmon it keeps giving me this error "Problem in getData procedure (disconnected USB device?)" I have tried everything I can think of, different Pi, different versions of Raspbian/PyRadmon and different serial USB converters but the problem still persists.
Any suggestions what to try to get it working?
Last edit: 10 years 4 months ago by James_Gy.
10 years 4 months ago #2084 by James_Gy
The exact error message I'm getting is,
"Problem in getData procedure (disconnected USB device?) => geiger 1:
invalid literal for int() with base 10: ''
10 years 4 months ago #2087 by ThibmoRozier
Thanks for reporting the bug.
Will look at the issue asap.
10 years 4 months ago #2122 by James_Gy
Any solution to the issue yet?
10 years 3 months ago #2123 by ThibmoRozier
Sadly, no. I am trying to reproduce it in the little time I have.
I think it might be that change I made to the way of opening serial devices.
Will give that a check as well.
10 years 3 months ago #2201 by ThibmoRozier
So I might have something...
Will need some work though.
Would you be able to run some tests and send over the debugging logs?
Time to create page: 0.162 seconds
Solar powered Raspberry Pi 4 server stats: CPU 59% Memory 15% Swap 17% CPU temp=64.2'C Uptime 17 Days
