J305 conversion factor
3 months 3 weeks ago #7170 by FSM19
J305 conversion factor was created by FSM19
Does anyone have a conversion factor for the Chinese J305 tube? I've just realised when I changed over counters, I put in one rather than the SBM20 I had been using.
3 months 3 weeks ago #7171 by Simomax
Replied by Simomax on topic J305 conversion factor
It is either 0.00332 or 0.00812. I have no idea which, or even if they are correct. I have been using 0.00812 for the J305, but I'm unsure if this is correct. I have never found a solid answer to this, nor have I ever found an actual proper data sheet for this tube, only a couple of tables on aliexpress/amazon/ebay that state their sensitivity, and I have found differing numbers for the same tube. I also think there has been more than one iteration of the J305 as some measure 88mm and some measure more. I also have a J305 that is sensitive to light, and one that isn't, and I have one that looks like a copy of the J305 with no markings on the tube. It is these discrepancies that puts me off using the J305.
There is some discussion about the conversion factor on Steadramon's ESPGeiger github page here:  https://github.com/steadramon/ESPGeiger/discussions/14
If I had a more solid answer, I' d be happy to help, but I've been struggling with this myself.
3 months 3 weeks ago #7172 by Simomax
I asked ChatGPT if it could find the conversion factor. It says the recommended number is 0.00332 for background monitoring. The conversation is in the PDF attached.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
The following user(s) said Thank You: iotdevicesdev
3 months 2 weeks ago #7175 by iotdevicesdev
It seems that AI quotes our publications. You can read them here:
Geiger tube J305: How to calculate the conversion factor of CPM to μSv/h. Technical note:
https://iot-devices.com.ua/en/geiger-tube-j305-how-to-calculate-the-conversion-factor-of-cpm-technical-note-en/
Geiger tube J305 conversion factor: differences between the coefficient for source radiation power and absorbed dose. Technical note:
https://iot-devices.com.ua/en/geiger-tube-j305-conversion-factor-difference-for-radiation-source-power-and-absorbed-dose-technical-note-en/
Best Regards,
Oleksii
IoT-devices, LLC
The following user(s) said Thank You: nu3e, FSM19
2 months 2 weeks ago - 2 months 2 weeks ago #7244 by ChrisLX200
Replied by ChrisLX200 on topic J305 conversion factor
Today I received a new J305b dated 2025, it is 107mm long, not UV-sensitive, and seems to provide a stable background count rate similar to the SBM-20 in one of my other counters, Obviously this is not an exhaustive test but I'll be doing more direct comparative experiments in the near future.
Last edit: 2 months 2 weeks ago by ChrisLX200.
2 months 2 weeks ago #7247 by Simomax
I bought a new CAJOE counter with J305 a few months ago, hoping it would be light sensitive. Sadly it's not in the slightest. So I have one that is very sensitive to light, and one that isn't in the slightest. The older (2021?) is the light sensitive tube, the new tube is not.
Time to create page: 0.180 seconds
Solar powered Raspberry Pi 4 server stats: CPU 32% Memory 13% Swap 12% CPU temp=62.3'C Uptime 5 Days
