× For discussion of news and events happening around the world right now
Iran nuclear sites hit - seemingly little to no radiation being reported
6 days 4 hours ago #7416 by jnissen
As in the subject. Was expecting to hear of elevated background radiation if these sites were hit. Then again if they were under 100's of feet of rock then it may have just buried all of the material. Comments
6 days 3 hours ago #7418 by Radslug
Iran is saying that they'd already evacuated all personnel and moved all nuclear materials when the attacks happened. Perhaps that is true. Also, when the Tepco plant at Fukushima melted down, there was a delay between the releases of material (or later, material stirred up into the air by heavy equipment) and when it reached stations to the East.
5 days 12 hours ago #7419 by Simomax
None of these sites were reactors. Fordow and Natanz are (were) enrichment facilities. They deal mostly with UF6 (Uranium Hexafluoride) which is a gas above 56℃. The gas is run through centrifuges to enrich the uranium. If bombed the UF6 could vaporize and react with moisture to produce HF gas (hydrogen fluoride) and uranyl compounds that would be localized to the area and not drift off much in the wind. The Esfahan facility is a Uranium production facility - they take ore and process it into yellowcake then UF4 (Uranium Tetrafluoride) a green solid, then to UF6 which is then sent to the Fordow and Natanz facilities for enrichment. Like Fordow and Natanz, if Esfahan was blown up the fallout would be localized and not like traditional nuclear fallout. My understanding is the regular fallout we all know is only produced by a reactor or spent fuel exploding, or a nuclear bomb.
I suspect there will be some fallout, but not in the traditional sense. And this will be localized to the areas. Fordow and Natanz's centrifuges were underground, whereas Esfahan was mostly overground.
2 hours 29 minutes ago #7426 by Sonarflash
Good and concise info about the sites. Looks like President Trump stretched, bent and mutilated the truth. (again-as usual).
Mind, I wouldn't want to be an uneducated Iranian worker sent in to clean up the mess...
Time to create page: 0.134 seconds
Solar powered Raspberry Pi 4 server stats: CPU 37% Memory 14% Swap 13% CPU temp=64.2'C Uptime 9 Days
