High readings in Stockholm, Sweden
10 years 10 months ago #1558
by Gamma-Man
High readings in Stockholm, Sweden was created by Gamma-Man
Last evening I had 25 readings of 173 to 241 CPM from 19:04 UTC to 19:28 UTC.
Before and after these readings the level are normal.
The reader is placed ouside on a balcony and the only possible visitor may be the neighbors cat, which I hope is more or less clean from radioactivity.
Any thinkable explanation for this high readings during this period?
Carl
Carl
10 years 10 months ago #1559
Replied by Juzzie on topic High readings in Stockholm, Sweden
a bad/dirty gm tube commection has caused this kind of problem for me lately...
The following user(s) said Thank You: Gamma-Man
10 years 10 months ago - 10 years 10 months ago #1560
Replied by Bert490 on topic High readings in Stockholm, Sweden
Don't rule out the cat. One of our members in Georgia, USA has a cat that underwent radiation therapy:
http://www.radmon.org/index.php/kunena/station-detections/105-high-readings-in-ga#558]
Last edit: 10 years 10 months ago by Bert490.
10 years 10 months ago #1561
Replied by mw0uzo on topic High readings in Stockholm, Sweden
Interesting. Is this with the radbox? Keep all your data and keep logging and let's see if it reoccurs. From the data it does look like a passing radioactive object, close to the detector. Maybe radioactive cat stopped to have a sniff?
- Sonarflash
- Premium Member
- Thank you received: 15
10 years 10 months ago #1562
by Sonarflash
Replied by Sonarflash on topic High readings in Stockholm, Sweden
Aside from dirty/loose connections and a radioactive cat, I wonder about wind direction. Can you find out the prevailing wind direction that night?
What came to mind was potential venting from the Chernobyl coffer. With such political chaos in the Ukraine, not likely we would hear much.
Does Sweden have a government radiological monitoring net that you could check?
10 years 10 months ago #1564
by Gamma-Man
Replied by Gamma-Man on topic High readings in Stockholm, Sweden
Yes I probably could find out the wind direction, but so could you.
I doubt that the political chaos you mention should have any impact of information about Chernobyl. The reason is simple, there are way to many scientists and other professionals of various nationality working on a daily basis in Chernobyl.
I believe that I do not have access to those monitoring systems that the Swedish authorities has, but I may be wrong.
Thank you for your input.
Regards
Carl
Regards
Carl
Time to create page: 0.228 seconds
