- Software discussions
- Arduino Code
- (Solved) Arduino code on ESP8266 keep crashing on submitting CPM to Radmon
4 years 8 months ago - 4 years 8 months ago #5934
Chaps and chapesses, I have an issue with some arduino code constantly crashing my ESP8266 after a random(ish?) length of time. I started this project some months ago, fell into this crash/reboot mess and have pretty much left it alone until yesterday where I'm picking it up to try and get it sorted. Details of the hardware/software and what I have done thus far:
The hardware is a GK Radmon unit (yellow board) with the supplied ESP8266 - https://sites.google.com/site/diygeigercounter/home/gk-radmon
I am running the OLED and an ebay BME280 (temp/humidity/pressure sensor). No changes to original hardware at all.
I am running my own code pretty much from scratch, with the exception of some original functions, such as the HV setup, BME280 init and reading and Radmon submission. I have since changed the Radmon submission code, but not much, and this had no effect.
Features/functions are as follows (with their current state)
Record pulses at interrupt
Calculating CPM - Enabled
Reading BME280 - Disabled
Displaying on OLED - On startup only, after 60 seconds is disabled (unless button is pressed)
Submitting to Blynk - Disabled
Submitting to Radmon - Enabled
Submitting to another webserver - Disabled
Sending CPM to serial (much like the NET-IO GC10) - Disabled
Wifi connection - Always enabled
With the code for Radmon submission disabled this unit ran for over 4 months submitting to my Blynk server without a single hiccup. As soon as the Radmon submission code is enabled it will run for so long (between 5000 and 6000 seconds) then throw an exception (29). I have an extensive debug log, but all it shows is it runs for so long, starts to fail on Radmon submission, then crash, then reboot (internal watchdog timer). Then lather, rinse, repeat, over and over.
I have cut right back on the features of this counter (listed above) so it does little more than just take counts, calculate CPM and then submit to Radmon. I initially thought it was something with the timers clashing, so disabled everything else and still the same. So, with all features
In the debug log I have recorded overnight the crash intervals are as follows:
Uptime before crash (in seconds since reboot): 5615, 5888, 5409, 5349, 5710, 5709, 5411.
As you can see the crash interval is similar, but not exact and appears to always be between 5000 and 6000 seconds. It was only yesterday I put in the code to count uptime and this is my finding so far.
The original GK Radmon code for Radmon.org submission does exactly the same as the code I pulled from the 'software' page except I had to change the line client.print(int(f_value[CPM])); to client.print(int(CPM))); as it was submitting strange numbers!
So far I know that the unit runs for months with everything enabled except Radmon submission. As soon as Radmon submission is enabled it will crash after some time. With everything disabled and only Radmon submission enabled, it will crash. So this leads me to one of two theories; 1, it is something in the arduino code or library causing the crash. Or 2, it is something hanging up on the Radmon server or sending back something causing the crash. I suspect the former as opposed to the latter, unless mw0uzo can shed any light from logs etc? It is also important to realize that the code I am running differs massively in the way it works to the original code written for the GK Radmon. the original code was designed to make a sample, submit the sample and then go to sleep for a while, wake up and sample again. I think each time this happened it would disconnect from WiFi then reconnect for the next time it woke up. My code is running all the time, and connected to WiFi constantly as it would record results to Blynk every 10 seconds.
Things I have not tried yet:
Re-coding the entire HTTP Radmon.org submission from scratch. Done this. Massive improvement. No crashes so far. I'm running with this for a while.
There is a WiFiClient clientGet function that may work better - not tried as yet I'm talking bollocks. It is just some different code to that I have already. This is running, and well.
Writing a php page on my server to simulate that of Radmon's submission to see if it is some difference between web servers.
Throwing the thing in a drawer, forgetting about it and calling it a day.
Any help on this would be very much welcomed! In fact, help me fix this and I will give you a giant hug!
A portion of the debug log up until and when it crashes:
This is the arduino code function for submitting to Radmon.org. Most is original GK Radmon code, with the exception of where I client.print the URL that I have changed for original code from the Radmon software page (below the commended out section):
This is the full code if anyone is interested with settings.h following:
settings.h
Uptime: 5349 Seconds
Connecting to radmon.org
Request: GET /radmon.php?function=submit&user=radspod_north&password=My_Submission_Password&value=31&unit=CPM
HTTP/1.0
HOST: radmon.org
closing connection
Sent to Radmon: OK
Uptime: 5409 Seconds
Request: GET /radmon.php?function=submit&user=radspod_north&password=My_Submission_Password&value=35&unit=CPM
HTTP/1.0
HOST: radmon.org
closing connection
Sent to Radmon: OK
Uptime: 5469 Seconds
connection failed
Sent to Radmon: FAIL
Uptime: 5529 Seconds
connection failed
Uptime: 5592 Seconds
connection failed
Uptime: 5649 Seconds
connection failed
Uptime: 5709 Seconds
connection failed
Exception (29):
epc1=0x40206fcf epc2=0x00000000 epc3=0x40100401 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff0c00 end: 3fff0e80 offset: 01a0
>>>stack>>>
3fff0da0: ae342452 61646133 61373732 40206fcd
3fff0db0: ae342452 00000037 3ffefe60 3ffef9c4
3fff0dc0: 00577a15 3ffefe58 4020bc08 3ffef9c4
3fff0dd0: 00577a15 00001f90 3ffef9d8 40206b7c
3fff0de0: 401071a8 ae342452 401071a8 ae342452
3fff0df0: 3ffe8a90 00000000 3ffef9a0 4020bf4c
3fff0e00: 3ffe84e4 00000000 3ffef9a0 40203b6a
3fff0e10: 00000000 00000000 3ffef55c 40207784
3fff0e20: 402353c2 3ffefe50 00000000 00000001
3fff0e30: 40236583 00000002 00000000 40106952
3fff0e40: 3fff147c 402068fc 3ffefe50 3ffefe58
3fff0e50: 3ffefa84 3ffef8f0 3ffefe50 402051b2
3fff0e60: 3fffdad0 00000000 3ffefe50 4020bc54
3fff0e70: feefeffe feefeffe 3ffefe60 40100710
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v614f7c32
~ld
Starting Radspod V2......This is the arduino code function for submitting to Radmon.org. Most is original GK Radmon code, with the exception of where I client.print the URL that I have changed for original code from the Radmon software page (below the commended out section):
void updateRadmon() {
seconds = millis() / 1000;
if (config.debugRadmon) { Serial.println("\r\n\r\nUptime: " + String(seconds) + " Seconds"); }
sBuff = "Sent to Radmon: ";
if (sendToRadmon())sBuff += "OK"; // call function that sends to Radmon.org
else sBuff += "FAIL";
if (config.debugRadmon) { Serial.println(sBuff);
// RADMON.ORG send function:
// Radmon only accepts CPM value. It's generally slower to connect to and get a response from.
// Sometimes the response isn't captured in DEBUG but the request is usually accepted.
boolean sendToRadmon() {
Serial.print("Connecting to ");
Serial.println(RadmonHost);
const int httpPort = 80;
if (!client.connect(RadmonHost, httpPort)) {
if (config.debugRadmon) Serial.println("connection failed");
return false; // report that it didn't connect
/* Original GK Radmon code
// We now create a URI for the request
String url = "function=submit&user=";
url += UserName;
url += "&password=";
url += PassWord;
url += "&value=";
url += int(CPM);
url += "&unit=CPM";
Serial.print("Request: ");
Serial.println(url);
// This will send the request to the server
client.print(String("GET /radmon.php?") + url + " HTTP/1.1\r\n" +
"Host: " + RadmonHost + "\r\n" +
"Connection: close\r\n\r\n");
End of Original GK Radmon code */
if (config.debugRadmon) { Serial.print("Request: GET /radmon.php?function=submit&user="); }
client.print("GET /radmon.php?function=submit&user=");
if (config.debugRadmon) { Serial.print(String(UserName) + "&password="); }
client.print(UserName); client.print("&password=");
if (config.debugRadmon) { Serial.print(String(PassWord) + "&value="); }
client.print(PassWord); client.print("&value=");
if (config.debugRadmon) { Serial.println(String(CPM) + "&unit=CPM"); }
client.print(int(CPM));
client.print("&unit=CPM");
if (config.debugRadmon) { Serial.println(" HTTP/1.0"); }
client.println(" HTTP/1.0");
if (config.debugRadmon) { Serial.println("HOST: radmon.org"); }
client.println("HOST: radmon.org");
client.println();
delay(100); // give some time after request (was 10, changed to 100 to see if that increases stability)
if (config.debugRadmon) { // Read all the lines of the reply from server and print them to Serial
while (client.available()) {
String line = client.readStringUntil('\r');
Serial.print(line);
Serial.println();
Serial.println("closing connection");
client.flush(); // need to flush or read buffer else it only sends once
//delay(1000); // reported to improve reliability try - if needed
//client.stop();
return true; // report that it connected
}This is the full code if anyone is interested with settings.h following:
#include <ArduinoOTA.h>
#include <BlynkSimpleEsp8266.h>
#include <SimpleTimer.h>
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include "SSD1306.h"
#include "SSD1306MyFonts.h"
#include <Wire.h>
#include "SparkFunBME280.h"
#include "settings.h"
BME280 bme280; // for Temp, Humidity & pressure
SSD1306 display(0x3c, SDA_PIN, SCL_PIN); // OLED address (0x3c), SDA (GPIO0), SCL(GPIO2)
WiFiClient client; // Use WiFiClient class to create TCP connections
IPAddress ip;
int timerTask1, // Calculate CPM
timerTask2, // Update Radmon
timerTask3, // Update Blynk
timerTask4, // Update HTTP
timerTask5, // Read BME280
timerTask6, // Update display #1
timerTask7, // Update display #2
timerTask8, // Update display #3
blynkConnected,
buttonPressed,
currentDisplay;
long CPM;
float uSvhr,
humidity,
temp,
pressure;
float f_value[3]; // floats for CPM, Dose, RSSI
String dBuff,
sBuff;
unsigned int PWMval; // PWM setting for HV
unsigned int lastPotVal = 0; // used for pot HYSTERESIS
volatile unsigned long totalCounts = 0; // Total counts
int cpsCount = 0; // Used for calculating CPM. This var counts the amount of detections in one second
int cpsDispCount; // Used for displaying CPS
int cpmArray[60]; // Array used for storing CPS over 60 seconds. Each index equals the CPS over a given second
int cpmArrayStep = 0; // Used for stepping the index of above array when calculating CPM
float conversionFactor = 0.0057; // Conversion factor for uSv/hr - 0.00833 for LND712 / 0.0057 for SBM-20 / 0.00812 for J305B
int screenMillis;
unsigned long seconds;
SimpleTimer timer;
int lastConnectionAttempt = millis();
int connectionDelay = 5000; // try to reconnect every 5 seconds
void setup()
Serial.begin(115200);
delay(500);
if (config.debugStartup) { Serial.println("Starting Radspod V2......\r\n\r\n"); }
//Serial.println("Starting Radspod V2......\r\n\r\n"); //------------------------------------------------------------------------------------------------
if (config.debugStartup) { Serial.println("Setting Pins."); }
pinMode(LED_PIN, OUTPUT); // setup LED pin
pinMode(INT_PIN, INPUT_PULLUP); //set pin 2 turn on the internal pullup
if (config.debugStartup) { Serial.println("Setting SDA, SCL Pins."); }
Wire.pins(SDA_PIN, SCL_PIN); // define pins used for I2C
if (config.debugStartup) { Serial.println("Starting Wire."); }
Wire.begin();
if (config.debugStartup) { Serial.println("Setting WiFi Mode."); }
WiFi.mode(WIFI_STA);
if (config.debugStartup) { Serial.println("Starting Blynk."); }
//Serial.println("Starting Blynk."); //------------------------------------------------------------------------------------------------
#if defined(USE_LOCAL_SERVER)
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS, SERVER, PORT);
#else
Blynk.begin(AUTH, WIFI_SSID, WIFI_PASS);
#endif
while (Blynk.connect() == false) {}
if (config.debugStartup) { Serial.println("Starting OTA."); }
//Serial.println("Starting OTA."); //------------------------------------------------------------------------------------------------
ArduinoOTA.setHostname(OTA_HOSTNAME);
ArduinoOTA.begin();
ip = WiFi.localIP();
if (config.debugStartup) { Serial.println(ip); }
//Serial.println(ip); //------------------------------------------------------------------------------------------------
if (config.debugStartup) { Serial.println("Initializing Display."); }
// initialize and setup dispaly . . .
display.init();
display.flipScreenVertically(); // display pins on top
display.setContrast(255);
display.clear();
display.setFont(ArialMT_Plain_16);
display.setTextAlignment(TEXT_ALIGN_CENTER); // center the following (anchor at 64px)
display.drawString(64, 0, "Radspod V2"); // version #
display.display(); // display what you got so far
if (config.useBME280) {
if (config.debugStartup) { Serial.println("Initializing BME280."); }
initBME280(); // initialize BME280 sensor
if (config.debugStartup) { Serial.println("Attaching Interrupt."); }
attachInterrupt(INT_PIN, GetEvent, FALLING); // Geiger event on INT_PIN triggers interrupt
if (config.debugStartup) { Serial.println("Checking HV Pot."); }
checkHVpot(); // check the HV pot and set the HV
if (config.debugStartup) { Serial.println("Writing Display Buffer."); }
dBuff = String(PWMtoVolts(PWMval)); // convert current PWM to volts and display
dBuff += " VOLTS";
if (config.debugStartup) { Serial.println("Displaying Buffer."); }
display.setFont(ArialMT_Plain_24);
display.drawString(64, 18, dBuff);
display.setFont(ArialMT_Plain_10);
display.drawString(64, 52, "Schmoozie version.");
display.display();
if (config.debugStartup) { Serial.print(PWMtoVolts(PWMval));
Serial.println(" Volts"); }
if (config.debugStartup) { Serial.println("Setup complete."); }
delay(2000);
display.clear();
// --------------------- Timers --------------------- //
if (config.debugStartup) { Serial.println("Defining timer tasks."); }
timerTask1 = timer.setInterval(cpmInterval, calculateCPM);
if (config.useRM) { timerTask2 = timer.setInterval(radmonInterval, updateRadmon);
if (config.debugStartup) { Serial.print("Using Radmon. Timer set at ");
Serial.println(radmonInterval);
if (config.useBL) { timerTask3 = timer.setInterval(blynkInterval, updateBlynk);
if (config.debugStartup) { Serial.print("Using Blynk. Timer set at ");
Serial.println(blynkInterval);
if (config.useHT) { timerTask4 = timer.setInterval(httpInterval, updateHTTP);
if (config.debugStartup) { Serial.print("Using HTTP. Timer set at ");
Serial.println(httpInterval);
if (config.useBME280) { timerTask5 = timer.setInterval(bme280Interval, readBME280);
if (config.debugStartup) { Serial.print("Reading BME280. Timer set at ");
Serial.println(bme280Interval);
timerTask6 = timer.setInterval(mainDisplayInterval, updateDisplay);
timerTask7 = timer.setInterval(secondDisplayInterval, updateDisplay2); // we create then disable this timer to be enabled later
timer.disable(timerTask7);
timerTask8 = timer.setInterval(thirdDisplayInterval, updateDisplay3); // we create then disable this timer to be enabled later
timer.disable(timerTask8);
// ------------------- End Timers ------------------- //
currentDisplay = 1;
screenMillis = millis();
if (config.debugStartup) { Serial.println("Running!!!!"); }
//Serial.println("Running!!!!\r\n"); // ------------------------------------------------------------------------------------------------
Serial.println("\r\n\r\n\r\nUptime: " + String(seconds) + " Seconds");
void changeDisplay()
if (config.debugDisplay) { Serial.print("\r\nChanging display - current display: "); }
currentDisplay += 1;
if (currentDisplay > 3) { currentDisplay = 1; }
if (config.debugDisplay) { Serial.println(String(currentDisplay)); }
if (currentDisplay == 1)
timer.enable(timerTask6);
updateDisplay();
else if (currentDisplay == 2)
timer.disable(timerTask6);
timer.enable(timerTask7);
updateDisplay2();
else if (currentDisplay == 3)
timer.enable(timerTask8);
updateDisplay3();
void displayOff()
if (config.debugDisplay) { Serial.println("\r\nDisplay off - stopping display timers."); }
currentDisplay = 0;
display.clear();
display.display();
void updateDisplay()
f_value[LAST_RSSI] = WiFi.RSSI(); // RSSI is 0 to -100 - closer to 0 (lower -) the better
sBuff = "RSSI: ";
sBuff += String(f_value[LAST_RSSI]);
sBuff += "db";
display.clear();
if (config.debugDisplay) { Serial.println("\r\nWriting Display Buffer."); }
dBuff = "RSSI: ";
dBuff += String(int(f_value[LAST_RSSI])); // convert current PWM to volts and display
dBuff += "db";
if (config.debugDisplay) { Serial.println("Displaying Buffer."); }
display.setTextAlignment(TEXT_ALIGN_LEFT);
display.drawString(0, 0, dBuff);
display.setTextAlignment(TEXT_ALIGN_RIGHT);
if (blynkConnected)
display.drawString(128, 0, "Blynk OK");
else
display.drawString(128, 0, "Blynk NOK");
dBuff = String(CPM);
dBuff += " CPM";
display.drawString(64, 40, dBuff);
dBuff = String(uSvhr);
dBuff += " uSvhr";
display.drawString(64, 24, dBuff);
dBuff = String(temp, 1);
if (config.useCelsius) dBuff += "°C "; // degree char is now displaying - was not working
else dBuff += "°F ";
dBuff += String(int(humidity));
dBuff += "% ";
if (config.useBAR) {
dBuff += String(int(pressure));
dBuff += "mb";
else {
dBuff += String(pressure);
dBuff += "in";
Serial.println("Displaying BME280.");
Serial.println(dBuff);
display.drawString(64, 12, dBuff);
display.display();
if (screenTimeout > 0 ) {
if (millis() > screenMillis + screenTimeout) {
displayOff();
void updateDisplay2()
if (totalCounts > 999999999) { totalCounts = 0; }
sBuff = "Total Counts: ";
sBuff += String(totalCounts);
if (config.debugDisplay) { Serial.println(sBuff); }
display.clear();
dBuff = "Total: ";
dBuff += String(totalCounts); // display total counts
display.drawString(64, 0, dBuff);
dBuff = " RSSI: ";
dBuff += "db";
display.drawString(0, 18, dBuff);
if (blynkConnected)
display.drawString(128, 18, "Blynk OK");
else
display.drawString(128, 18, "Blynk NOK");
dBuff += " Volts";
display.drawString(64, 30, dBuff);
dBuff += "% ";
dBuff += "mb";
else {
dBuff += "in";
if (config.debugDisplay) { Serial.println("Displaying BME280.");
Serial.println(dBuff); }
display.drawString(64, 54, dBuff);
display.display();
displayOff();
void updateDisplay3()
display.clear();
dBuff = "Total: ";
dBuff = String(cpsDispCount); // convert current PWM to volts and display
dBuff += " CPS";
if (config.debugDisplay) { Serial.println(dBuff); }
dBuff += " Volts";
display.drawString(0, 42, dBuff);
dBuff = String(CPM); // convert current PWM to volts and display
dBuff += " CPM";
display.drawString(128, 42, dBuff);
dBuff = " RSSI: ";
dBuff += "db";
display.drawString(0, 54, dBuff);
if (blynkConnected)
display.drawString(128, 54, "Blynk OK");
else
display.drawString(128, 54, "Blynk NOK");
display.display();
displayOff();
url += UserName;
url += PassWord;
url += "&value=";
url += int(CPM);
url += "&unit=CPM";
client.println();
Serial.print(line);
Serial.println();
//client.stop();
void updateBlynk() {
if (config.useBL) {
if (config.debugBlynk) { Serial.println("Updating Blynk."); }
//Serial.print("."); //------------------------------------------------------------------------------------------------
Blynk.virtualWrite(vPIN_CPM, CPM);
Blynk.virtualWrite(vPIN_TEMPERATURE, String(temp));
Blynk.virtualWrite(vPIN_HUMIDITY, String(int(humidity)));
Blynk.virtualWrite(vPIN_PRESSURE, String(pressure));
Blynk.virtualWrite(vPIN_DOSE, String(uSvhr));
Blynk.virtualWrite(vPIN_RSSI, String(f_value[LAST_RSSI]));
Blynk.virtualWrite(vPIN_VOLTAGE, String(PWMtoVolts(PWMval)));
Blynk.virtualWrite(vPIN_TOTALCOUNTS, String(totalCounts));
Blynk.virtualWrite(vPIN_DBGDISPLAY, config.debugDisplay);
Blynk.virtualWrite(vPIN_DBGRADMON, config.debugRadmon);
Blynk.virtualWrite(vPIN_DBGBLYNK, config.debugBlynk);
Blynk.virtualWrite(vPIN_DBGHTTP, config.debugHTTP);
Blynk.virtualWrite(vPIN_DBGBME280, config.debugBME280);
Blynk.virtualWrite(vPIN_DBGCPMCALC, config.debugCPMcalc);
Blynk.virtualWrite(vPIN_DBGBUTTONS, config.debugButtons);
void updateHTTP() {
if (config.debugHTTP) { Serial.println("Doing the HTTP thang."); }
void readBME280() {
if (config.debugBME280) { Serial.println("Reading BME280."); }
float PaPress;
if (config.useCelsius) temp = bme280.readTempC(); // Convert Celsius to Fahrenheit
else temp = bme280.readTempF();
humidity = bme280.readFloatHumidity(); // Read humidity (percent)
Read pressure and convert to SEA LEVEL PRESSURE . . .
There are severial methods, the first 3 are here. Now that pow is supported method 4 is used
Method 1: Simple way to convert to SLP - good for lower elevations - no pow func required
from: http://www.sandhurstweather.org.uk/barometric.pdf
// PaPress = PaPress + (config.elevation / 9.2); // convert to SLP
Method 2: - adapted from Hans Matlab function
// PaPress = 1013.25 * (pow(PaPress / 1013.25, 0.190263) + pow(0.0000225577 * config.elevation, 5.25588));
Method 3: - adapted from - http://n5jlc.duckdns.org/
// PaPress = PaPress / (pow(1 - (config.elevation / 44330.0), 5.255));
No conversion if elevation = 0.
PaPress = bme280.readFloatPressure() / 100.0F; // read pressure convert to mb (100pa = 1hPa = 1mb)
// Method 4: most accurate sea level conversion, with temp compensation
// - from http://keisan.casio.com/exec/system/1224575267
if (config.elevation != 0) {
double temp1 = 1.0 - (( 0.0065 * config.elevation) / (bme280.readTempC() + (0.0065 * config.elevation ) + 273.15));
PaPress = PaPress * pow(temp1, -5.257);
if (config.useBAR) pressure = PaPress; // leave it in millibar
else pressure = PaPress / 33.8939F; // convert to inches Hg
if (config.debugBME280) { // print sensor data
Serial.print("Temperature: ");
Serial.print(temp, 2);
Serial.println(" degrees C/F");
Serial.print("Pressure: ");
Serial.print(pressure, 2);
Serial.print(" mb\t");
Serial.print(PaPress / 33.8939F, 2);
Serial.println(" Hg");
Serial.print("Humidity: ");
Serial.print(humidity, 2);
Serial.println(" %");
void calculateCPM() // Calculate the CPM
if (config.debugCPMcalc) { Serial.print("Calculating CPM: "); }
cpmArray[cpmArrayStep] = cpsCount; // Set the index in the CPM array to that of the current CPS. The index initially starts at 0 when powered on
cpmArrayStep++; // The next index we want to record
if (cpmArrayStep >= 60) // There are 60 indexes, one for every second in a minute. If the index goes out of the bounds of our 60 indexes then cycle back to index 0
cpmArrayStep = 0;
CPM = 0; // Var used to temporarily calculate CPM
unsigned int i;
for (i = 0; i < 60; i++) // Get the value at each index of the CPM array
CPM += cpmArray[i]; // Add each index together to give a total over 60 seconds
// Serial.print(cpmArray[i]);
// Serial.print(", ");
// Serial.println(" ");
cpsDispCount = cpsCount; // set this for use on the display as the current cps resets
cpsCount = 0; // Reset the CPS variable ready for sampling the next second
if (config.cpmSerialOn) { Serial.println(CPM); } // Print the current CPM to serial every interval if enabled
else if (config.debugCPMcalc) { Serial.println(CPM); }
uSvhr = CPM * conversionFactor; // Calculate uSv/hr from CPM using the conversion factor. CPM * conversion Factor = uSv/hr
if (config.debugCPMcalc) { Serial.print(uSvhr);
Serial.println(" uSv/hr"); }
// This function is called whenever the assigned Widget changes state
BLYNK_WRITE(vPIN_DISPBUTTON) { // vPin is the Virtual Pin assigned to a Button Widget
if (param.asInt()) { // Assumes if 1 then follow through..
changeDisplay();
BLYNK_WRITE(vPIN_DBGDISPLAY) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugDisplay = param.asInt();
BLYNK_WRITE(vPIN_DBGRADMON) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugRadmon = param.asInt();
BLYNK_WRITE(vPIN_DBGBLYNK) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugBlynk = param.asInt();
BLYNK_WRITE(vPIN_DBGHTTP) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugHTTP = param.asInt();
BLYNK_WRITE(vPIN_DBGBME280) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugBME280 = param.asInt();
BLYNK_WRITE(vPIN_DBGCPMCALC) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugCPMcalc = param.asInt();
BLYNK_WRITE(vPIN_DBGBUTTONS) { // vPin is the Virtual Pin assigned to a Button Widget
config.debugButtons = param.asInt();
void checkHVpot() {
unsigned int potVal;
potVal = analogRead(A0); // ADC Pin - 0-1V ONLY!!!
// don't keep re-adjusting the HV due to normal fluctuations in reading
if (potVal > lastPotVal + POT_HYSTERESIS || potVal < lastPotVal - POT_HYSTERESIS) {
PWMval = lmap(potVal, 0, 1023, HV_MIN_PWM, HV_MAX_PWM);
setHV (PWMval); // set HV
lastPotVal = potVal;
void setHV (int volts) {
if (volts == 0) analogWrite(PWM_PIN, 0); //must turn off PWM before WiFi
else {
analogWriteFreq(2500); // freq 2.5kHz best (must set first)
analogWrite(PWM_PIN, volts); // set the voltage
unsigned long PWMtoVolts(unsigned int PWM) {
// Volts against PWM was measured by reading through 1G ohm with manual range set.
// The data was plotted in Excel and a scatter graph made. Then a linear trend-line was used
// to derive the formula. A trend line with a max of 700V gave the best results.
unsigned long fVolts;
fVolts = (float(PWM) * 1.3429) + 130.35; // v1.2 PCB with STX13005
// conversion r2=0.9979 best for 300V - 700V
return fVolts; // return calculated voltage
void initBME280() {
int tempRtrn;
bme280.settings.commInterface = I2C_MODE;
if (config.adr77) bme280.settings.I2CAddress = 0x77; // Adafruit or Sparkfun BME280
else bme280.settings.I2CAddress = 0x76; // eBay BME280
//Run Mode; 0 = Sleep, 1 or 2 = Forced, 3 = Normal
bme280.settings.runMode = 3; // = Forced mode - takes reading once, stores it and sleeps
//Standby; 0-7 = .5ms-20ms (see doc)
bme280.settings.tStandby = 0; // = .5ms
//Filter; bits 0-4 = off-*16 FIR coefficients (see doc)
bme280.settings.filter = 0; // = Filter off
//Temp, Pressure, and humidity OverSample; bits 0-5 = skip-*16 (see doc)
bme280.settings.tempOverSample = 1; // = *1
bme280.settings.pressOverSample = 1; // = *1
bme280.settings.humidOverSample = 1; // = *1
tempRtrn = bme280.begin(); // init BME280
if (config.debugStartup) { // print init results
Serial.print("bme280.begin= ");
Serial.print(tempRtrn, HEX);
if (tempRtrn == 0x60) Serial.println(" Init OK");
else Serial.println(" Init FAIL");
delay(10); //BME280 requires 2ms to start up.
byte readButton(int buttonPin) { // reads LOW ACTIVE push button and debounces
if (digitalRead(buttonPin)) return HIGH; // still high, nothing happened, get out
else { // it's LOW - switch pushed
delay(DEBOUNCE_MS); // wait for debounce period
if (digitalRead(buttonPin)) return HIGH; // no longer pressed
else return LOW; // 'twas pressed
// rolling your own map function saves a lot of memory
unsigned long lmap(unsigned long x, unsigned long in_min, unsigned long in_max, unsigned long out_min, unsigned long out_max) {
return x > in_max ? out_max : (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
void GetEvent() { // ISR triggered for each new event (count)
totalCounts ++; // Increase total counts each time the interrupt is fired
cpsCount ++; // Increase var each time the interrupt is fired
digitalWrite(LED_PIN, HIGH); // flash LED as quickly as possible.
delayMicroseconds(50);
digitalWrite(LED_PIN, LOW);
void loop()
// check WiFi connection:
if (WiFi.status() != WL_CONNECTED)
// (optional) "offline" part of code
Serial.println("Blynk - Disconnected!");
blynkConnected = false;
// check delay:
if (millis() - lastConnectionAttempt >= connectionDelay)
// attempt to connect to Wifi network:
if (WIFI_PASS && strlen(WIFI_PASS))
WiFi.begin((char*)WIFI_SSID, (char*)WIFI_PASS);
else
WiFi.begin((char*)WIFI_SSID);
else
Blynk.run();
ArduinoOTA.handle();
blynkConnected = true;
timer.run();
if (readButton(SET_BUTTON) == LOW)
buttonPressed = true;
if (config.debugButtons) { Serial.println("Button Pressed"); }
else
if (buttonPressed == true) {
buttonPressed = false;
if (config.debugButtons) { Serial.println("Button Released"); }
changeDisplay();
}[/i][/i]settings.h
#define debug_Startup true
#define debug_Display false
#define debug_Radmon true
#define debug_Blynk false
#define debug_HTTP false
#define debug_BME280 false
#define debug_CPMcalc false
#define debug_Buttons false
// DEFINE YOUR WIFI NETWORK ...
#define WIFI_SSID "My_WiFi_SSID"
#define WIFI_PASS "My_WiFi_Password"
// PICK THE SITES YOU WANT TO SEND TO ...
#define SEND_TO_RADMON true // CPM will be sent to Radmon.org
#define SEND_TO_BLYNK false // all fields will be sent to Blynk
#define SEND_TO_HTTP false // all fields will be sent to HTTP
#define PRINT_TO_SERIAL false // prints the current CPM every second to serial.
// For Radmon.org: set the next 3 lines to your Radmon.org UserName and Password . . .
const char* RadmonHost = "radmon.org"; // No need to change this
const char* UserName = "My_Radmon_Username"; //Your Radmon.org user name
const char* PassWord = "My_Submission_Password"; //Your Radmon.org submission password
// Blynk Auth Code
#define AUTH "MY_Blynk_Auth_Token"
// Blynk local server settings - comment out to use cloud server
#define USE_LOCAL_SERVER
#define SERVER "myserver.co.uk"
#define PORT 8080
// Web server and PHP page to post to...
const char* host = "myserver.co.uk";
String url = "radspod/north/postdata.php";
// Over The Air Hostname
#define OTA_HOSTNAME "Radspod V2"
// Blynk Virtual Pins - Base
#define vPIN_CPM V1
#define vPIN_TEMPERATURE V2
#define vPIN_HUMIDITY V3
#define vPIN_PRESSURE V4
#define vPIN_DOSE V5
#define vPIN_RSSI V6
#define vPIN_VOLTAGE V7
#define vPIN_TOTALCOUNTS V8
#define vPIN_DISPBUTTON V10
#define vPIN_DBGDISPLAY V11
#define vPIN_DBGRADMON V12
#define vPIN_DBGBLYNK V13
#define vPIN_DBGHTTP V14
#define vPIN_DBGBME280 V15
#define vPIN_DBGCPMCALC V16
#define vPIN_DBGBUTTONS V17
#define cpmInterval 1000 // (in ms) How often the cpm is calculated. Don't change this without changing the array size etc.
#define radmonInterval 60000 // (in ms) How often data is sent to Radmon. Minimum 60 seconds (60000).
#define blynkInterval 10000 // (in ms) How often data is sent to Blynk.
#define httpInterval 10000 // (in ms) How often data is posted to HTTP.
#define bme280Interval 5000 // (in ms) How often the BME280 is read.
#define mainDisplayInterval 2000 // (in ms) How often the main display is updated.
#define secondDisplayInterval 1000 // (in ms) How often the 2nd display is updated.
#define thirdDisplayInterval 1000 // (in ms) How often the 3rd display is updated.
#define screenTimeout 60000 // (in ms) Screen timeout. 0 to disable timeout. OLED will burn if left on permanently
#define USE_BME280 false // true if BME280 is used
#define USE_ADR77 false // true = Adafruit or Sparkfun BME-280, false = eBay
#define ELEVATION 0 // elevation in meters if BME280 used
#define USE_BAR true // true = millibars, false = inches Hg
#define CELSIUS true // true = Celsius, false = Fahrenheit
#define SDA_PIN 0 // I2C SDA pin (pulled up) + PGM button and LED
#define SET_BUTTON 0 // also used to set HV adj mode
// TX 1 // wired to serial comm
#define SCL_PIN 2 // I2C SCL pin (pulled up)
// RX 3 // wired to serial comm
#define DONE_PIN 4 // input from solar charger DONE pin
#define PWM_PIN 5 // PWM for HV generation
#define LED_PIN 12 // flashes with count
#define INT_PIN 13 // Geiger events on this pin cause interrupt
#define LAST_RSSI 2 // (can't use "RSSI")
#define POT_HYSTERESIS 1 // amount of change in pot value needed to trigger a recalculation of HV (keeps the value from bouncing around)
#define HV_MIN_PWM 14 // minimum PWM duty - 14/1023 = 1.3% (~100V)
#define HV_MAX_PWM 620 // maximum PWM duty - 620/1023 = 60% (~875V)
#define DEBOUNCE_MS 50 // button debounce period in mS (50 is good)
struct strConfig {
boolean useRM = SEND_TO_RADMON;
boolean useBL = SEND_TO_BLYNK;
boolean useHT = SEND_TO_HTTP;
boolean cpmSerialOn = PRINT_TO_SERIAL;
boolean useBME280 = USE_BME280;
boolean adr77 = USE_ADR77;
boolean useBAR = USE_BAR;
boolean useCelsius = CELSIUS;
boolean debugStartup = debug_Startup;
boolean debugDisplay = debug_Display;
boolean debugRadmon = debug_Radmon;
boolean debugBlynk = debug_Blynk;
boolean debugHTTP = debug_HTTP;
boolean debugBME280 = debug_BME280;
boolean debugCPMcalc = debug_CPMcalc;
boolean debugButtons = debug_Buttons;
long elevation = ELEVATION;
} config;
Last edit: 4 years 8 months ago by Simomax.
4 years 8 months ago #5935
Replied by Simomax on topic Help Needed! Arduino code on ESP8266 keep crashing on submitting CPM to Radmon
I forgot to add a couple of things:
I'm using Arduino OTA. This seems to make no difference whether enabled or not. Sometimes the ESP8266 will not recover from a crash and won't reboot, as has just happened now, and requires the reset button pressed or power cycling the unit. Latest debug log where it did not recover from the crash:
After a little digging it appears the memory address responsible(?) for causing the crash is that of the ESP8266 SPI flash memory - Address 40200000h as noted on this page here: https://www.esp8266.com/wiki/doku.php?id=esp8266_memory_map
It is tempting to strip the whole code down to simply connecting to WiFi and submitting a random number (between 10 and 30) to Radmon.org and see what happens. I'm 99% sure this isn't a conflict with other code in the program but is born from the HTTP code itself. I have very similar code running on three other units sending data to my web server and Blynk, with varying hardware (sensors/displays) and those three all run flawlessly. On checking the code for them I notice that I 'POST' the data to my server, as opposed to 'GET' as is used in the radmon.org arduino code. I could do with a new wall for banging my head against....
Uptime: 5443 Seconds
Request: GET /radmon.php?function=submit&user=radspod_north&password=My_Submission_Password&value=27&unit=CPM
HTTP/1.0
HOST: radmon.org
closing connection
Sent to Radmon: OK
Uptime: 5503 Seconds
connection failed
Uptime: 5565 Seconds
connection failed
Exception (29):
epc1=0x40206fd3 epc2=0x00000000 epc3=0x4020180b excvaddr=0x00000000 depc=0x00000000
ctx: cont
>>>stack>>>
3fff0da0: ae342452 61646133 61373732 40206fd1
3fff0dc0: 0055c33c 3ffefe58 4020bc0c 3ffef9c4
3fff0dd0: 0055c33c 00001f90 3ffef9d8 40206b80
3fff0df0: 3ffe8a90 00000000 3ffef9a0 4020bf50
3fff0e10: 00000000 00000000 3ffef55c 40207788
3fff0e20: 402353c6 3ffefe50 00000000 00000001
3fff0e30: 40236587 00000002 3ffef55c 40106952
3fff0e40: 3fff147c 40206900 3ffefe50 3ffefe58
3fff0e60: 3fffdad0 00000000 3ffefe50 4020bc58
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt resetAfter a little digging it appears the memory address responsible(?) for causing the crash is that of the ESP8266 SPI flash memory - Address 40200000h as noted on this page here: https://www.esp8266.com/wiki/doku.php?id=esp8266_memory_map
4 years 8 months ago #5936
I'm testing different code. I have ditched the old submission function entirely and trying some different code. It is running and submitting fine so far. Will have to see what it is like at >5000 seconds runtime. So far so good.
Uptime: 339 Seconds
Updating Radmon...
>>> Connecting to host: radmon.org
Sending data....
GET /radmon.php?function=submit&user=radspod_north&password=My_Submission_Password&value=39&unit=CPM HTTP/1.1
Host: radmon.org
User-Agent: ESP8266/1.0
Connection: close
End of sending data....
Response:
HTTP/1.1 200 OK
>>> Closing host: radmon.orgPlease Log in or Create an account to join the conversation.
4 years 8 months ago #5937
Replied by mw0uzo on topic Help Needed! Arduino code on ESP8266 keep crashing on submitting CPM to Radmon
Got to be something pointery with the string constructor or the HTTP library. It will be interesting to see the new code that works better.
Failing fixing it, I would probably go back to the standard C way of constructing the HTTP request in a character array and use strncpy to place in the strings and a counter to track the write position.
The extra help making things easier with the String type should all be well tested though. I also wonder if the http client should be destroyed and unalloc'd after a request.
4 years 8 months ago - 4 years 8 months ago #5939
The new code has surpassed 9000 seconds uptime. It seems OK so far. Fingers crossed. I have a feeling I know why it was failing with the previous code, and yes, could be what you mention about destroying the http client afterwards. In the previous code (I think) the http client was using an existing instance of WiFiClient. This was being used over and over and whilst there is a flush function it was never stopped. This new code looks like it creates a new instance of WiFiClient each time and stops it after use.
It looks happy. This is the new code below:
Uptime: 9039 Seconds
Updating Radmon...
Sending data....
GET /radmon.php?function=submit&user=radspod_north&password=My_Submission_Password&value=24&unit=CPM HTTP/1.1
Host: radmon.org
Connection: close
Response:
HTTP/1.1 200 OK
>>> Closing host: radmon.orgIt looks happy. This is the new code below:
Serial.println("\r\nUptime: " + String(seconds) + " Seconds");
Serial.println("\r\nUpdating Radmon...");
WiFiClient clientGet;
const int httpGetPort = 80;
//the path and file to send the data to:
String urlGet = "/radmon.php";
urlGet += "?function=submit&user=";
urlGet += UserName;
urlGet += "&password=";
urlGet += PassWord;
urlGet += "&value=";
urlGet += int(CPM);
urlGet += "&unit=CPM";
Serial.print(">>> Connecting to host: ");
if (!clientGet.connect(RadmonHost, httpGetPort)) {
Serial.print("Connection failed: ");
} else {
Serial.println("Sending data....");
clientGet.println("GET " + urlGet + " HTTP/1.1");
Serial.println("GET " + urlGet + " HTTP/1.1");
clientGet.print("Host: ");
clientGet.println(RadmonHost);
Serial.println("Host: " + String(RadmonHost));
clientGet.println("User-Agent: ESP8266/1.0");
Serial.println("User-Agent: ESP8266/1.0");
clientGet.println("Connection: close\r\n\r\n");
Serial.println("Connection: close\r\n\r\n");
unsigned long timeoutP = millis();
while (clientGet.available() == 0) {
if (millis() - timeoutP > 10000) {
Serial.print(">>> Client Timeout: ");
clientGet.stop();
return;
Serial.println("End of sending data....\r\n\r\nResponse:");
//just checks the 1st line of the server response. Could be expanded if needed.
while (clientGet.available()) {
String retLine = clientGet.readStringUntil('\r');
Serial.println(retLine);
break;
} //end client connection if else
Serial.print(">>> Closing host: ");
clientGet.stop();
4 years 8 months ago #5941
- Arduino Code
Time to create page: 0.301 seconds
