ESP8266 Arduino sketch + hardware documentation
3 years 6 months ago #6386
by nu3e
Replied by nu3e on topic ESP8266 Arduino sketch + hardware documentation
Hi Lars,
Verify that your Wi-Fi credential strings (ssid and pswd) are correct for your home 2.4 GHz network.
As you probably know, address block 169.254.0.0/16 is reserved for IPv4 link-local addresses, which are automatically assigned to interfaces when other means of address assignment fail or are not available.
To determine the cause of your connection failure, I suggest https://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/readme.html#diagnostics
John
- Without changing the code, try "Enable Debugging in IDE" and see what appears on the Arduino serial monitor.
- You can enable debugging programmatically by calling Serial.setDebugOutput(true) after Serial.begin(9600).
- Printing the return value of WiFi.status() or calling WiFi.printDiag(Serial) should be helpful.
John
3 years 6 months ago #6388
by Alterna
Replied by Alterna on topic ESP8266 Arduino sketch + hardware documentation
Above issue solved
ESP8266 is not able to use Wifi channel 13 and 14!
My wifi modem was using channel 13
Best regrads from Lars, Denmark
3 years 6 months ago #6389
by nu3e
Thanks for sharing your solution. I found this article which states channels 12, 13, and 14 don't work properly on the ESP8266:
https://olimex.wordpress.com/2021/12/10/avoid-wifi-channel-12-13-14-when-working-with-esp-devices/
I would never have discovered that, because here in the USA only channels 1-11 are allowed.
John
John
Time to create page: 0.125 seconds
