IS there a FAQ or a list of Radiation Monitors / Gieger Counters
7 months 3 weeks ago #7479 by skippyinspace
Hi All,
Starting to look at the Radiation / Giegier counter for home use to monitor outside radiation and report on personal website, here and the likes of GC-Mon. etc
I was wondering if there was a list of commercially available units that could do this? Or a FAQ post where models are added etc
Or if the community had a prefered model.
My Tech skills are very average and dont really want to go down a DIY route, Though a simple non solder kit, with pre built code for a pi etc could also be an option.
Thanks in advance
IanĀ
PeterheadĀ
Scotland
7 months 3 weeks ago #7480 by Simomax
As far as I know, there is no list, as there are no commercially available counters that will work with radmon/GC-Mon etc. out of the box, to my knowledge. BroHogan (DIYGeiger) was really the only person making such a thing and he has stopped supplying them now, or at least until his stocks run out. However, he stopped shipping to the UK after brexit due to red tape.
It is a shame that Steadramon hasn't released his ESPGeiger-HW, because that would have fit your bill right away, less the personal website recording - it can be done, but I had to jump through some hoops to get there.
The easiest way would be to get something like a NET-IO GC10 or similar. Maybe a CAJOE RadiationD 1.1, or the new ESP32 version and wire it up to an ESP8266 (Wemos D1 Mini or similar) and install the ESPGeiger firmware on it. It requires only three wires, Ground, +5v and either the serial output from the GC10, or other, or pulse output from the CAJOE, or other pulse counter. But I get it, that even three wires can seem daunting with little experience. ESPGeiger has a wifi manager and a proper interface for configuration, so you don't ever need to touch the code. It supports radmon, GMC (GC-Map), Thingspeak, MQTT and Home Assistant integration using MQTT. Most of my counters that report to radmon.org use ESPGeiger firmware now.
I may have a solution. I've dropped you a PM.
Time to create page: 0.171 seconds
Solar powered Raspberry Pi 4 server stats: CPU 55% Memory 15% Swap 17% CPU temp=64.2'C Uptime 17 Days
