- Commericial geiger counters
- Connecting a Ludlum 177 to Radmon with the Data port?
6 months 4 days ago #7513
by Irish
Connecting a Ludlum 177 to Radmon with the Data port? was created by Irish
Hello All, I have a Ludlum 177 Benchtop meter than runs pretty much 24/7 and I'd love to contribute but I'm struggling to get the data port to send proper CPM signal out to my desktop. I'm wondering if anyone has had any luck getting the Ludlum data ports to work or if anyone has any tips.
6 months 2 days ago #7514
Replied by Simomax on topic Connecting a Ludlum 177 to Radmon with the Data port?
I have just had a quick look at the manual for your counter (
here
) and it states that on the 9-pin D connector, pin 3 is ground and pin 5 gives a negative pulse output of ~-4V. It is very doable, but will depend on your skillset and how you want to go about it. Despite is being called a data port, it lacks an actual data stream. Besides pin 5 (pulse) the others are all just voltage rails/ancillary stuff, so pin 5 is all we have to work with.
There are a few options available for getting the counts online, three that I can think of right now are:
If going the ESP32/8266 route, I would strongly suggest a Wemos D1 mini and Steadramon's ESPGeiger firmware. I think this would be the easiest and fastest way of getting your counter online and it supports other services too. I reckon you could simply just hook up your pin 5 right to the Wemos, flash it with ESPGeiger, configure and go.
- Use Radlog Pro on a windows PC and use the soundcard to pick up the pulses from your counter.
- Connect the pulse output to a ESP32 or ESP8266 (Wemos D1 Mini etc).
- Connect the pulse output to a Raspberry Pi.
The following user(s) said Thank You: Irish
Time to create page: 0.232 seconds
