Calibration Check Sources
9 years 1 month ago #3352 by ChrisLX200
Is there anywhere in the UK one can obtain low-activity check sources for calibrating DIY geiger counters (and gamma spectrometers) - something like a 0.1uC Cs137 button? Are any of these things exempt or does it require endless form-filling? I do have the usual active sources (radium dials, smoke-detector tabs, and also some chemicals like Thorium Oxide and Uranium acetate) but of course the exact activity of these is unkown so not much use for calibrating any instrumentation. In the USA and Germany you can just buy these things mail-order but that doesn't appear possible here in the UK - or is it?
ChrisH
Time to create page: 0.128 seconds
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 16% Swap 18% CPU temp=64.2'C Uptime 17 Days
