Multiple tubes
4 years 3 months ago #6138
Multiple tubes was created by FSM19
I have three SBM20s in stock, plus a couple of homebuilt counters. My plan is to connect all three tubes in one counter, am I correct in thinking each tube should have its own limiting resisto?
4 years 3 months ago #6139
by Alpha01
Replied by Alpha01 on topic Multiple tubes
Yes, you're right. During the discharge of one tube, the voltage drops around 70V. If other tubes are connected in parallel, they will be in shortcut as well, so unable to detect anything until recovery of the one triggered. So they must be powered independently by their own limiting resistor. Ideally, the first part of the detection circuit should also be tripled...
4 years 3 months ago #6140
Replied by FSM19 on topic Multiple tubes
Should be simple on my counters then, only an extra three of four components for each tube.
4 years 3 months ago #6147
by Alpha01
Perfect.
Just another point to consider: if high counting rate is expected, then check if HV section is able to supply the average current increase (HV voltage before the limiting resistor should not drop outside the plateau voltage limits for SBM20.
