duration geiger tube
10 years 9 months ago #1591 by adrenasxxx
Hi All,
i read something about the duration of the tube (SBM20), someone wrote that the reading is reliable till 1M ticks, others wrote that the duration is eternity.. do you have some deterministic value?
thank you for your support.
Adriano
10 years 9 months ago #1594 by Sonarflash
Replied by Sonarflash on topic duration geiger tube
SBM-20
Parameters and characteristics .
Life (pulses) at least 2*10^10
SBM-20, SBM-20U
HARD BETA and GAMMA GM DETECTORS
GENERAL SPECIFICATIONS
Gas Filling Ne + Br2 + Ar
Cathode Material Stainless Steel, 50 mkm
Maximum Length (mm) 108 / 101
Effective Length (mm) 91.0 / 83.5
Maximum Diameter (mm) 11
Effective Diameter (mm) 10
Connector Pin
Operating Temperature Range 0C -60 to +70
WALL SPECIFICATIONS
Areal Density (mg/cm2) 40
Thickness (mm) 0.05
: ELECTRICAL SPECIFICATIONS
Minimum Anode Resistor 1.0 megohm
Recommended Anode Resistor 5.1 megohm
Recommended Operating Voltage (volts) 400
Operating Voltage Range (volts) 350 - 475
Initial voltage (volts) 260 - 320
Plateau length (volts) at least 100
Maximum Plateau Slope (%/100 volts) 10
Minimum Dead Time (at U=400V, micro sec) 190
Working range (mkR/s) 0.004 - 40
Working range (mR/h) 0.014 - 144
Gamma Sensitivity Ra226 (cps/mR/hr) 29
Gamma Sensitivity Co60 (cps/mR/hr) 22
Inherent counter background (cps) 1
Tube Capacitance (pf) 4.2
Weight (grams) 10 / 9
The following user(s) said Thank You: adrenasxxx
10 years 9 months ago #1595 by adrenasxxx
Replied by adrenasxxx on topic duration geiger tube
Really Thanks for the useful information SonarFlash!
Regards,
Adriano
Time to create page: 0.131 seconds
Solar powered Raspberry Pi 4 server stats: CPU 64% Memory 14% Swap 17% CPU temp=61.8'C Uptime 17 Days
