Forum
Geiger counter discussions
Geiger-Muller tubes
SBT-11 Interior Photo
Sonarflash
Offline
Premium Member
Blind since 1966 - 51+ years with insight.
Thank you received: 15
9 years 4 weeks ago - 9 years 4 weeks ago #3491
by Sonarflash
trouble with editor attachments:evil:
Here goes one last attempt at making an attachment. The inside of an SBT-11.
Just in case the attachment doesn't work (again), the photo shows the inside of an SBT-11 (CNT-11) Russian GM tube with the mica window removed.
There is a rectangular sheet metal cathode at the bottom of a rectangular recess. This is connected common to both external ground connector pins. There are four channels folded into this metal. 4 anode wires are nested inside these four channels. The middle two wires are slightly thinner than the outer two wires and they are common, connected to the centre anode pin external connector.
This is the non-'A' (alpha) designated tube.
Last edit: 9 years 4 weeks ago by
Sonarflash. Reason: difficulty with editor attachment
Forum
Geiger-Muller tubes
Time to create page: 0.119 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=62.3'C Uptime 17 Days
