Nukes on the map?
10 years 5 months ago #1967 by DExUS
Replied by DExUS on topic Nukes on the map?
@Bert490 , A1 block was damaged in 1977 and is not funcitonal, V1 was also shutdown and only 2 blocks of V2 are running.
Shame that A1 was damaged by a very stupid accident , it was an experimental reactor that can burn natural uranium without any enrichment.
A1 was damaged when they were adding new fuel rods and forgot the Silica gel pack there and the tiny granules clogged cooling circuit, the fuel casette has overheated and melted down and also the moderator pipe.
Heavy water has entered the reactor and thus rendering it unusable.
10 years 5 months ago - 10 years 5 months ago #1968 by Simomax
Replied by Simomax on topic Nukes on the map?
Alright, I have got together a CSV (attached in the zip file below) with all the main nuclear sites in the UK. The sites are not just power stations but decommissioned sites, research facilities, fuel production, Naval sites etc. They are all listed on the UK Radioactive Waste Inventory, so although it may be an insignificant site, it is hot!
File Attachment:
File Name: UKNuclearSites.zip
File Size:2 KB
Last edit: 10 years 5 months ago by Simomax.
The following user(s) said Thank You: mw0uzo, bethsalem
10 years 5 months ago - 10 years 5 months ago #1969 by Bert490
Replied by Bert490 on topic Nukes on the map?
Well, I went through Wikipedia's comprehensive list of Reactors to find the ones that are operating but under 1000 MW (and over 100 MW) and put it into the attached .csv. Maybe the icons on the map should be different for Operating >1 GW, Operating under 1 GW, Decommissioned plant, Processing facility, Research site, Naval site.
DExUS, it's a shame about A1, There are very few designs that can use un-enriched Uranium.
File Attachment:
File Name: NPRoperati...ions.zip
File Size:1 KB
Last edit: 10 years 5 months ago by Bert490.
10 years 5 months ago - 10 years 5 months ago #1971 by mw0uzo
Replied by mw0uzo on topic Nukes on the map?
Ok thanks for the lists. Just leave it as it is at the moment, I will do the code and finalise the table format and then additions/modifications can be made as necessary.
Last edit: 10 years 5 months ago by mw0uzo.
10 years 5 months ago #1972 by Simomax
Thanks mw0uzo. :)
@Bert490: Yes, different icons on the map would be very cool.
10 years 1 month ago #2405 by VePink
Replied by VePink on topic Nukes on the map?
Have anyone prepared a list?
Station SPINGSE:
RKSB-104 + ArduinoUno
Time to create page: 0.180 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 18% CPU temp=64.2'C Uptime 17 Days
