New install under Windows10
7 years 7 months ago #4273 by gw7eri
Hi Daniel, I have re-installed Radlog on a new pc running win10. All is running fine except my username / password is being rejected at the server. APRS is disabled too. I wonder if it would be possible for you to have a look and re-set my password at some stage. Best regards, Alex - GW7ERI
7 years 7 months ago #4274 by ThibmoRozier
It's now the same password as on the forum. :)
7 years 7 months ago #4277 by gw7eri
Replied by gw7eri on topic New install under Windows10
Thanks for the reply ThibmoRozier - just tried and its still not working for me :( When I click 'check user name and password' I get the response Checking for valid user...' then 'User validation failed, server error. The operation has timed out.' Another box pops up and says username and/or password incorrect. I've tried username both in upper and lower text and re-typed password loads of times but just get the same result.... I'm at a bit of a loss now as all was well till I migrated to a new(er) pc. :(
7 years 7 months ago #4278 by mw0uzo
Replied by mw0uzo on topic New install under Windows10
Hi gw7eri
Leave it logging with the password you want, i'll check the logs and update it manually over the weekend.
7 years 7 months ago #4280 by gw7eri
Hi Daniel, thank you, will do - no problem at all! I remember the last time this happened you reset my record and all was ok.
Sorry to be a pest :)
Best 73's
Alex
7 years 7 months ago #4290 by mw0uzo
Sent you a PM with password reminder. Is RadLog/pyradmon running?
Didn't
Time to create page: 0.236 seconds
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 14% Swap 18% CPU temp=67.2'C Uptime 17 Days
