cannot send CPM data using wget
7 years 7 months ago - 7 years 7 months ago #4342 by pilovis
My system stopped sendig data to radmon.org a few days ago, It was using wget to send data:
/usr/bin/wget -O /dev/null "http://radmon.org/radmon.php?function=submit&user=pilovis2&password=zzzzz&value=xx"
I double checked my system and everything works well, did you change anything on your side?
Thanks.
P.S.: I'm now using curl but not sure it is the right method:
/usr/bin/curl -s "http://radmon.org/radmon.php?function=submit&user=pilovis2&password=zzzzz&value=xx"
7 years 6 months ago - 7 years 6 months ago #4343 by mw0uzo
You have to specify &unit=CPM at the end. Only supported unit is CPM at this time.
I haven't changed anything here as I have been busy with work, so there should be no change in recent behaviour.
Last edit: 7 years 6 months ago by mw0uzo.
Time to create page: 0.111 seconds
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 15% Swap 17% CPU temp=61.8'C Uptime 17 Days
