- Just published my 3D printed designs and Arduino code for an outdoor monitor
4 years 5 months ago #6092
by rjelbert
Just published my 3D printed designs and Arduino code for an outdoor monitor was created by rjelbert
Hello
Just thought you might want to see my 3D printed designs for an outdoor mounted geiger counter. The chassis I designed fits inside a standard ABS waterproof case and holds the geiger counter PCB, Arduino Leonardo and the PoE ethernet hat. I've also included a 3D printed pole mount but the ABS case can also be attached to a wall. The Arduino code is also linked from the Thingiverse web site. This is how I built my Midhurst monitoring station.
https://www.thingiverse.com/thing:5322167
Regards
Richard
Regards
Richard
4 years 5 months ago #6109
Replied by mw0uzo on topic Just published my 3D printed designs and Arduino code for an outdoor monitor
Ah very cool! Thanks for posting it.
I have used my 3d printer for quite a few cases now, as long as they don't need to be perfect finish they work very well.
4 years 4 months ago - 4 years 4 months ago #6114
by CDEM
Replied by CDEM on topic Just published my 3D printed designs and Arduino code for an outdoor monitor
Thank you for the decent design rjelbert
i assume this is the correct harware:
https://aliexpress.com/item/1005004137844019.html
Last edit: 4 years 4 months ago by CDEM.
4 years 4 months ago #6115
by rjelbert
Replied by rjelbert on topic Just published my 3D printed designs and Arduino code for an outdoor monitor
Hi. Thanks! Yes that looks like the same kit I used in my station. It seems to be quite common.
Richard
Richard
4 years 4 months ago #6116
by rjelbert
Hi. The internal chassis is not seen so the quality settings can be low. I used a 0.8mm nozzle to get a stronger print but with lower quality. That said any normal 0.5 or 0.4 nozzle will be fine. Personally I always like to make nice looking prints so probably take longer than most getting the settings right - the PET-G is not my normal filament so I had retraction / stringing issues but it's all a learning experience
4 years 4 months ago #6128
by rjelbert
Hi. No problem. I decided to use a commercial sealed ABS case in the end but the internal chassis to mount everything is 3D printed. The optional pole mount is also 3D printed. I hope others will use the design and my Arduino code to make more monitors!
R
R
