- Introductions and FAQ
- Howtos and FAQs
- Bash script to send data to Radmon from Mygeiger ver.3 PRO (serial over USB)
5 years 3 months ago - 5 years 3 months ago #5734
by pilovis
#!/bin/bash
##serial port setup
#stty -F /dev/ttyUSB0 speed 9600 cs8 -parenb -cstopb
## continuously print values in a file
#(stty raw; cat > /tmp/received.txt) < /dev/ttyUSB0
## continuously print values in console
#echo | (stty raw; cat) < /dev/ttyUSB0
## print one value in console
#/usr/bin/head -n1 /dev/ttyUSB0
## by pilovis 2109 Italy - www.vinchio.org
# main loop (infinite)
while true
do
# CPM reading loop (60 seconds)
while true
do
# populate a tmp file with CPM data received from USB serial connection, one read per line
cat /dev/ttyUSB0 > /tmp/received.txt
# send reading loop to background and go further
done &
# count 60 seconds and then stop the CPM reading loop and the serial data reading / file writing
pid=$!
/bin/sleep 60 && kill -TERM $pid; killall cat
/bin/sleep 1
# calculate the mean value of the readings and insert the integer value rounded to the CPM variable
cpm=$(/usr/bin/awk '{ total += $1; count++ } END { print total/count }' /tmp/received.txt | /usr/bin/awk '{printf("%.f\n",$0)}')
# insert CPM value in a tmp file, updated every minute
/bin/echo $cpm > /tmp/cpm.txt
# calculate uSv/h value from CPM and put it in a tmp file, updated every minute
/bin/sed 's/$/ * .0057/' /tmp/cpm.txt | /usr/bin/bc | /usr/bin/awk '{printf("%.2f\n", $1)}' > /tmp/usvh.txt
# send CPM data to radmon.org
/usr/bin/curl -s "http://radmon.org/radmon.php?function=submit&user=myuser&password=mypassword&value=$cpm&unit=CPM"
# change myuser & mypass in the above line with your radmon login data
/bin/sleep 7
# OPTIONAL: notify alarm if CPM is above the alarm level
alarm=75 # alarm level
if [ $cpm -gt $alarm ];
then
/bin/echo "Alarm CPM = "$cpm > /dev/null 2>&1;
# put your alarm on script here
#/bin/echo 1 > /sys/class/gpio/gpio1/value # switch on GPIO1
else
/bin/echo "everything is normal" > /dev/null 2>&1;
# put your alarm off script here
#/bin/echo 0 > /sys/class/gpio/gpio1/value # switch off GPIO1
fi;
# wait 10 seconds and then restart main loop
/bin/sleep 10
done
##serial port setup
while true
do
while true
do
done &
pid=$!
/bin/sleep 1
/bin/sleep 7
then
else
fi;
/bin/sleep 10
done
Last edit: 5 years 3 months ago by pilovis.
5 years 3 months ago #5735
by pilovis
Replied by pilovis on topic Bash script to send data to Radmon from Mygeiger ver.3 PRO (serial over USB)
5 years 3 months ago #5737
Replied by mw0uzo on topic Bash script to send data to Radmon from Mygeiger ver.3 PRO (serial over USB)
Nice! Thank you pilovis!
- Howtos and FAQs
Time to create page: 0.153 seconds
