How to put geiger counter readings on your own website
11 years 10 months ago - 11 years 10 months ago #40 by mw0uzo
1. Get the last reading submitted to radmon.org for a particular station
Remember to replace my username with yours.
<img src="http://www.radmon.org/radmon.php?function=cpmreading&user=mw0uzo" />
2. Show the raw data graph
<img src="http://www.radmon.org/mw0uzo/graphlasthour.png" alt="" />
3. Show the 24hr graph
<img src="http://www.radmon.org/mw0uzo/graphtoday.png" alt="" />
4. Redraw these graphs with the latest data
<form action="http://www.radmon.org/radmon.php?user=mw0uzo&function=graphtoday&refresh=true" method="post">
  <input type="submit" value="Update daily graphs">
</form>
5. Use the FTP function in RadLog to save your local RadLog graph every x minutes
a) Tick 'Save graph to ftp'. Set the rate that you want to upload the graph, default is every 5 minutes.
b) Tick 'Supress errors' unless you are having problem with FTP and want to see the error messages.
c) Set the desired resolution
d) Check your FTP settings on your webserver, create a new FTP account if necessary. See your webhost FAQ.
e) Enter the FTP username and password
f) Enter the server address. e.g. yourserver.com
g) The uploaded filename is 'ftpchart.png'
6. CPM meter for your website
<img src="http://www.radmon.org/radmon.php?function=cpmmeter&user=mw0uzo" />
Last edit: 11 years 10 months ago by mw0uzo.
The following user(s) said Thank You: Frank, OM1AMJ, maredentro72, Kevinspage, Electrodemente
11 years 10 months ago - 11 years 10 months ago #41 by mw0uzo
Testing out CPM meter for your website:
Testing last CPM reading, text only
Ok these don't work in the new forum due to security. But they will work fine on your webpage, or in your browser.
11 years 10 months ago - 11 years 10 months ago #65 by OM1AMJ
You can also use PHP code to obtain text value from radmon site. ;)
Example: http://viking.home.sk/om1amj/radmon.php
PHP code:
<?php
$user = "XXXXX";    //set user
$url = "http://radmon.org/radmon.php?function=showuserpage&user=$user";
$page = fopen($url, 'r');
$content = "";
while( !feof( $page ) ) {
$buffer = trim( fgets( $page, 4096 ) );
$content .= $buffer;
$startcpm = "Last reading: ";   //read CPM from RADMON.ORG
$endcpm = " CPM";
preg_match( "/$startcpm(.*)$endcpm/s", $content, $match);
$cpm = $match[1];
$starttime = "CPM on ";   //read time of measurements from RADMON.ORG
$endtime = "UTC at";
preg_match( "/$starttime(.*)$endtime/s", $content, $match);
$time = $match[1];
$usvh = round($cpm/175.43, 4);   //convert CPM to uSv/h (175.43 is for SBM-20 tube), change to your GM tube
echo "$user";
echo " <br />\n";
echo "$time UTC";
echo " <br />\n";
echo "$cpm CPM";
echo " <br />\n";
echo "$usvh uSv/h";
Last edit: 11 years 10 months ago by OM1AMJ.
11 years 10 months ago #66 by mw0uzo
There is also the function
http://www.radmon.org/radmon.php?function=lastreading&user=mw0uzo
Which returns the CPM and DateTime recorded for the last reading in plaintext
53 CPM on 2014-10-26 22:55:50UTC at Cardiff, UK
11 years 10 months ago #67 by OM1AMJ
I didn't know about this feature. :(
11 years 10 months ago #68 by mw0uzo
My bad, I will have to document more of the functions :silly:
Time to create page: 0.190 seconds
Solar powered Raspberry Pi 4 server stats: CPU 67% Memory 15% Swap 17% CPU temp=63.7'C Uptime 17 Days
