Radmon -> Google Gauge visualization
7 years 5 months ago #4369 by ZschorlRad
Sorry, was my mistake.
Look again the script. I have changed the end.
7 years 5 months ago #4370 by pilovis
No way, with php5 it does not work, tested on two different servers, Debian and Ubuntu.
Was it coded for php7?
7 years 5 months ago - 7 years 5 months ago #4371 by pilovis
first of all, your URLs are wrong:
$url = " www.radmon.org/radmon.php?function=lastreading&user=$user ";
should be:
$url = "http://www.radmon.org/radmon.php?function=lastreading&user=$user";
the same for the others.
Anyway, it still doesn't work, I think you made some mistakes coding this piece of script, please correct it, test it and post it again.
Thanks.
Last edit: 7 years 5 months ago by pilovis.
7 years 5 months ago #4372 by ZschorlRad
The code with some changed things:
<?php
$user = "xxxxxxx"; // change to your user name
$warning = "0.3";
$alert = "0.85";
$size = "150";
$page = fopen($url, 'r');
$content = "";
while( !feof( $page ) ) {
$buffer = trim( fgets( $page, 4096 ) );
$content .= $buffer;
$startcpm = "";
$endcpm = " CPM";
preg_match( "/$startcpm(.*)$endcpm/s", $content, $match);
$cpm = $match[1];
$usvh = round($cpm/175.43, 4);   //convert CPM to uSv/h (175.43 is for SBM-20 tube), change to your GM tube
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
   "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title><?php echo "Google Gauge - $user"; ?></title>
<meta name="robots" content="noindex,follow">
<meta name="googlebot" content="nosnippet,noarchive">
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta HTTP-EQUIV="Pragma" CONTENT="no-cache">
<meta HTTP-EQUIV="Expires" CONTENT="-1">
<meta http-equiv="refresh" content="120">
<style type="text/css">
  body { background-color: #AFC3C9; }
  #container { height: 100%; width: 100%; display: table; }
  #inner { vertical-align: middle; display: table-cell; }
  #gauge_div { width: <?php echo "$size"; ?>px; margin: 0 auto; }
.auto-style1 {
	text-align: left;
.auto-style2 {
	text-align: center;
	font-family: Arial, Helvetica, sans-serif;
	font-size: small;
.auto-style3 {
	font-family: "Trebuchet MS", "Lucida Sans Unicode", "Lucida Grande", "Lucida Sans", Arial, sans-serif;
</style>
<script type='text/javascript' src='https://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js'></script>
<script type='text/javascript' src='https://www.google.com/jsapi'></script>
<script type='text/javascript'>
  // maximum value for the gauge
  var max_gauge_value = 0.4;
  // name of the gauge
  var gauge_name = 'µSv/h';
  // global variables
  var chart, charts, data;
  // load the google gauge visualization
  google.load('visualization', '1', {packages:['gauge']});
  google.setOnLoadCallback(initChart);
  // display the data
  function displayData(point) {
    data.setValue(0, 0, gauge_name);
    data.setValue(0, 1, point);
    chart.draw(data, options);
  // load the data
  function loadData() {
    // variable for the data point
    var p;
      p = <?php echo "$usvh"; ?>;
      // if there is a data point display it
      if (p) {
        displayData(p);
  // initialize the chart
  function initChart() {
    data = new google.visualization.DataTable();
    data.addColumn('string', 'Label');
    data.addColumn('number', 'Value');
    data.addRows(1);
    chart = new google.visualization.Gauge(document.getElementById('gauge_div'));
    options = {width: <?php echo "$size"; ?>, height: <?php echo "$size"; ?>, redFrom: <?php echo "$alert"; ?>, redTo: 1, yellowFrom: <?php echo "$warning"; ?>, yellowTo: <?php echo "$alert"; ?>, greenFrom: 0, greenTo: <?php echo "$warning"; ?>, minorTicks: 25, max: 1.000};
    loadData();
    // load new data every 120 seconds
    setInterval('loadData()', 120000);
</script>
</head>
<body>
<div class="auto-style2">
	<strong><span class="auto-style3">Ortsdosisleistung (ODL)</span></strong></div>
    <div id="container">
      <div id="inner">
        <div id="gauge_div" class="auto-style1"><br></div>
      </div>
    </div>
  </body>
</html>
It's tested on my site: Radiation instrument or All instruments
I hope, it works.
The following user(s) said Thank You: pilovis
7 years 5 months ago #4373 by pilovis
now it works!
Thanks a lot!!!
1 year 1 month ago #7434 by pilovis
It doesn't work anymore
Time to create page: 0.187 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 16% Swap 17% CPU temp=64.7'C Uptime 17 Days
