radmon.org API
3 years 9 months ago - 3 years 9 months ago #6310
Replied by Simomax on topic radmon.org API
I have added three small new API functions - ping, time and pingtime (detailed below).
Function
ping
Description
Returns a reply. Can be used to see if the server, or at least the web server is operational and online.
Examples
https://radmon.org/radmon.php?function=ping
Result
pong
Function
time
Description
Returns the server date and time in php format (Y-m-d H:i:s)
Examples
https://radmon.org/radmon.php?function=time
Result
2022-12-09 17:37:38
Function
pingtime
Description
Returns a reply and returns the server date and time in php format (Y-m-d H:i:s). The separator used is & sign instead of a space as this can easily be used to parse the string.
Examples
https://radmon.org/radmon.php?function=pingtime
Result
pong&2022-12-09 17:39:48
Function
ping
Description
Examples
Result
pong
Function
time
Description
Examples
Result
2022-12-09 17:37:38
Function
pingtime
Description
Examples
Result
Last edit: 3 years 9 months ago by Simomax.
3 years 8 months ago - 3 months 2 weeks ago #6316
Hello All!
Below is the complete user API for radmon.org. There is also a much prettier PDF attached at the bottom of this post. I shall endeavour to keep it up to date and let you all know of any updates as and when they happen.
Cheerio!
API Specification 2026-05-24
Functions are executed with the following URL:
https://radmon.org/radmon.php?function=[function]&[parameter]=[parameter]
Example: https://radmon.org/radmon.php?function=showuserpage&user=Simomax
General status functions
Function: getstatus
Parameters:
Description: Gets the status of the server.
Example: https://radmon.org/radmon.php?function=getstatus
Returns: 'Raspberry Pi 4 server stats: CPU 32% Memory 15% Swap 12% CPU temp=58.4'C Filesystem 63% used Uptime 12 Days'
Function: ping
Parameters:
Description: Returns a reply. Can be used to see if the server, or at least the web server is operational and online.
Example: https://radmon.org/radmon.php?function=ping
Returns: 'pong'
Function: time
Parameters:
Description: Returns the server date and time in php format (Y-m-d H:i:s).
Example: https://radmon.org/radmon.php?function=time
Returns: '2022-12-09 17:37:38'
Function: pingtime
Parameters:
Description: Returns a reply and returns the server date and time in php format (Y-m-d H:i:s). The separator used is & sign instead of a space as this can
Example: https://radmon.org/radmon.php?function=pingtime
Returns: 'pong&2022-12-09 17:39:48'
Station Submission
Function: submit
Parameters: user, password, value, unit
Description: Submits a station reading. Note: the unit should always be CPM.
Example: https://radmon.org/radmon.php?function=submit&user=Simomax&password=datasendingpassword&value=100&unit=CPM
Returns: 'OK'
Function: submitwithlatlng
Parameters: user, password, value, unit, latitude, longitude
Description: Submits a station reading and sets the station latitude and longitude. Note: the unit should always be CPM.
Example: https://radmon.org/radmon.php?function=submit&user=Simomax&password=datasendingpassword&value=100&unit=CPM&latitude=54.8097&longitude=-2.01445
Returns: 'OK'
Station Settings
Function: updatedescription
Parameters: user, password, description
Description: Used for updating the station description.
Example:
https://radmon.org/radmon.php?function=updatedescription&user=Simomax&password=datasendingpassword&description=My%20Station%20Is%20Fantas
tic!
Debug returns: 'Set user description successfully.'
Function: setlatitudelongitude
Parameters: user, password, latitude, longitude
Description: Sets the station latitude and longitude.
Example: https://radmon.org/radmon.php?function=setlatitudelongitude&user=Simomax&password=datasendingpassword&latitude=53.80951&longitude=-
3.014777
Debug returns: 'Set user latitude and longitude successfully.'
Function: setconversionfactor
Description: Used for setting the station's GM tube conversion factor.
Example: https://radmon.org/radmon.php?function=setconversionfactor&user=Simomax&password=datasendingpassword&value=0.00833
Debug returns: 'Set conversion factor successfully.'
Function: setwarnalert
Parameters: user, password, warn, alert
Description: Returns Sets the station's alert and warning levels.
Example: https://radmon.org/radmon.php?function=setwarnalert&user=Simomax&password=datasendingpassword&warn=70&alert=120
Debug returns: 'Set warn and alert level successfully.'
Function: setalertsenabled
Description: Enables alerts for the station.
Example: https://radmon.org/radmon.php?function=setalertsenabled&user=Simomax&password=datasendingpassword
Debug returns: 'Set alerts to enable successfully.'
Function: setalertsdisabled
Description: Disables alerts for the station.
Example: https://radmon.org/radmon.php?function=setalertsdisabled&user=Simomax&password=datasendingpassword
Debug returns: 'Set alerts to disable successfully.'
Station details
Function: showuserpage
Parameters: user
Description: Shows the station page for the user.
Returns: Displays the user page
Function: lastreading
*Updated 24/05/2026 - added in password requirement
Description: Displays the last reading of a station in CPM.
Example: https://radmon.org/radmon.php?function=lastreading&user=Simomax&password=datasendingpassword
Returns: '18 CPM on 2022-12-03 17:49:31UTC at Blackpool, Lancashire, United Kingdom'
Function: lastreadingusv
Description: Displays the last reading of a station in uSv/hr.
Example: https://radmon.org/radmon.php?function=lastreadingusv&user=Simomax&password=datasendingpassword
Returns: '0.225 uSv/hr on 2022-12-03 17:45:31UTC at Blackpool, Lancashire, United Kingdom'
Data Manipulation
Function: deletealerts
Parameters: user, password, hours
Description: Deletes a station's alerts for the last X hours.
Example: https://radmon.org/radmon.php?function=deletealerts&user=Simomax&password=datasendingpassword&hours=24
Debug returns: 'Deleted alerts successfully.'
Function: deleteabove
Parameters: user, password, hours, above
Description: Deletes any readings from the last X hours where they are above X CPM,
Example: https://radmon.org/radmon.php?function=deleteabove&user=Simomax&password=datasendingpassword&hours=10&above=35
Debug returns: 'Deleted user data above successfully.'
Function: deleteuserdatahours
Description: Deletes the last X hours of data.
Example: https://radmon.org/radmon.php?function=deleteuserdatahours&user=Simomax&password=datasendingpassword&hours=1
Debug Returns: 'Deleted user data for last hour successfully.'
Graph drawing
* Note - As of 24/05/2026 all graph drawing API user functions have been disabled due to abuse.
Function: forcegraphrefresh
Parameters: user
Description: Forces a refresh of the station's graphs.
Example: https://radmon.org/radmon.php?function=forcegraphrefresh&user=Simomax
Returns: 'Graphs successfully generated.' if successful, or 'Server is too busy. Try again another time.' if server load is high.
Function: drawall
Parameters: user
Description: Refreshes (draws) the daily, weekly and monthly graphs.
Example: https://radmon.org/radmon.php?function=drawall&user=Simomax
Returns: Nothing
Function: graphtoday
Parameters: user
Description: Refreshes today's graph.
Example: https://radmon.org/radmon.php?function=graphtoday&user=Simomax
Returns: Nothing
Function: graphweek
Parameters: user
Description: Refreshes the weekly graph.
Example: https://radmon.org/radmon.php?function=graphweek&user=Simomax
Returns: Nothing
Function: graphmonth
Parameters: user
Description: Refreshes the monthly graph.
Example: https://radmon.org/radmon.php?function=graphmonth&user=Simomax
Returns: Nothing
Function: graphquarter
Parameters: user
Description: Refreshes the quarterly graph.
Example: https://radmon.org/radmon.php?function=graphquarter&user=Simomax
Returns: Nothing
Function: drawgraph24hr
Parameters: user
Description: Draws a graph from the station's last 24 hours submissions.
Example: https://radmon.org/radmon.php?function=drawgraph24hr&user=radspod_north
Returns: A graph
Function: drawsmallgraph
Parameters: user
Description: Draws a small graph of the station's last 12 hours submissions.
Example: https://radmon.org/radmon.php?function=drawsmallgraph&user=Simomax
Returns: A small graph
CPM Graphics
Function: cpmreading
Parameters: user
Description: Draws a small png of the station's last submission and status indicator.
Example: https://radmon.org/radmon.php?function=cpmreading&user=Simomax
Returns: PNG image
Function: cpmmeter
Parameters: user
Description: Draws a small png horizontal bar the station's last submission.
Example: https://radmon.org/radmon.php?function=cpmmeter&user=Simomax
Returns: PNG image
Listing Functions
Function: showuserlist
Parameters:
Description: Displays a list of active stations.
Example: https://radmon.org/radmon.php?function=showuserlist
Returns: List of active stations
Function: showuserlistinactive
Parameters:
Description: Displays list of inactive stations.
Example: https://radmon.org/radmon.php?function=showuserlistinactive
Returns: List of inactive stations
Cheerio!
Function: getstatus
Parameters:
Function: ping
Parameters:
Returns: 'pong'
Function: time
Parameters:
Function: pingtime
Parameters:
Station Submission
Function: submit
Returns: 'OK'
Returns: 'OK'
Station Settings
Example:
tic!
3.014777
Station details
Parameters: user
Data Manipulation
Graph drawing
Parameters: user
Function: drawall
Parameters: user
Returns: Nothing
Parameters: user
Returns: Nothing
Function: graphweek
Parameters: user
Returns: Nothing
Parameters: user
Returns: Nothing
Parameters: user
Returns: Nothing
Parameters: user
Returns: A graph
Parameters: user
CPM Graphics
Parameters: user
Returns: PNG image
Function: cpmmeter
Parameters: user
Returns: PNG image
Listing Functions
Parameters:
Parameters:
Last edit: 3 months 2 weeks ago by Simomax.
Time to create page: 0.207 seconds
