RadLog Documentation
7 years 11 months ago #3957
RadLog Documentation was created by mw0uzo
RadLog Professional
This software uses your PC to interface with your geiger counter and send data to radmon.org
It can connect your your geiger counter via serial type USB adaptor and also by audio sampling of incoming pulses.
<Please help me out here! If you'd like to write a small section on configuring RadLog, please post and I'll edit it in. If you had issues with your particular geiger counter but got it working, please let us know the settings!>
7 years 11 months ago - 7 years 11 months ago #3958
Replied by mw0uzo on topic RadLog Documentation
Section
Using GPS receiver U-Blox 7 **Work in progress Ugh new drivers not compatible with .net com port access method**
Windows XP-8.1
Open device manger, open Ports. Plug in device. Wait for automatic install. The new port that appears is the one that needs to be selected in RadLog
Windows 10
Plug in device. Wait for automatic install. New driver doesn't use virtual COM port anymore! Bah!
Go to Device Manager and uninstall the u-blox 7 driver.
Download the Virtual Com Port (VCP) Driver: https://www.u-blox.com/sites/default/files/ubloxGnss_vcpDeviceDriver_windows_3264_v3.10.exe
Run the installer. When it's complete, you should see a new COM port under 'Ports'. This is the COM port to select in RadLog
*** Not compatible ***
Tab 'Settings'. Check Use GPS COM port. Click Refesh icon next to COM port selector. Select COM port assigned to GPS device.
Windows XP-8.1
Windows 10
Last edit: 7 years 11 months ago by mw0uzo.
7 years 11 months ago - 7 years 11 months ago #3959
Section
Resetting RadLog settings if there are problems upgrading or downgrading versions
Windows XP-10?
Open file manager. Select View, tick hidden items.
Use file manager to browse to C:/Users/youruser/AppData/Local/radmon.org/RadLog.exe_blah/1.0.0.0/
Delete the file user.xml
Windows XP-10?
7 years 11 months ago - 7 years 11 months ago #3961
Section
Setting up a geiger counter connected by USB, e.g. MyGeiger, BroHogan and NetIO counters
Most geiger counters that connect by USB do so by emulating a serial COM port. Go to Device Manager>Ports then disconnect/reconnect your counter. The COM port that changes is your counter.
A lot of geiger counters use the CP2103 Usb to Serial IC. You need to install the drivers from the manufacturers website.
Windows 10
Close down RadLog and disconnect your counter.
Install https://www.silabs.com/documents/public/software/CP210x_Windows_Drivers.zip
Reconnect your counter and start RadLog.
Windows XP-8.1
These used to work automatically. Can someone check this?
Go to Settings tab. Select 'Kit with USB/TTL serial interface'
Select 'MyGeiger, BroHogan and NetIO' for the Format.
Early MyGeigers run at 2400 baud. Later ones run at 9600, BroHogan and NetIO run at 9600 baud. Choose one.
Click the 'Start' button on the bottom right hand side and wait for approximately one minute. If the settings and drivers are working correct, you will see data!
Windows 10
Windows XP-8.1
7 years 11 months ago #4081
Section
Setting up RadLog in a Windows 10 VM (linux KVM) for serial port type counters
Install the silabs CP210x drivers on the Windows 10 VM
Go to virt-manager, vm settings
Click Add Hardware and select USB Passthrough. Select the CP210x USB device
The new COM port should come up as COM3.
If only COM1 is available. Remove the USB passthrough and add it again in virt-manager. Success will show a COM3 or above in Device Manager and the COM port list after a refresh in RadLog.
Time to create page: 0.186 seconds
