Greetings from Lithuania
6 years 8 months ago #4960 by Zhiniukas
Hello,
I am new to radiation measurements. I have this geiger counter with wemos d1 mini for data uploading.
6 years 8 months ago #4961 by mw0uzo
Replied by mw0uzo on topic Greetings from Lithuania
Welcome to radmon.org! Great to have another station sending data.
I see that is a wifi module so you must be homebrewing.
Let me know if I can help checking the logs for data sending requests. Check the API documentation in 'Help and FAQs'.
6 years 8 months ago #4965 by Zhiniukas
Replied by Zhiniukas on topic Greetings from Lithuania
Hello mw0uzo,
I get this reply from the server, when I try to send my data:
Error adding user account: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '54.7056274, E 25.3044141, 0, 0, 0)' at line 1
Incorrect.
Command line I copied from the Howtos ans FAQs:
http://radmon.org/radmon.php?function=submit&user=xxxxx&password=xxxxx1&value=20&unit=CPM
Thanx in advance.
Zhiniukas
6 years 8 months ago #4972 by mw0uzo
Ok this is because your station coordinates in your profile have been entered incorrectly, you do not need the N and S. I have corrected. Try again!
6 years 8 months ago #4975 by Zhiniukas
Now everything works. Thank you.
Zhiniukas.
6 years 5 months ago #5343 by Zhiniukas
Hello,
Can somebody delete my station data for today?
I had power supply failure and counter generated bunch of false data.
Time to create page: 0.141 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=63.7'C Uptime 17 Days
