3rd station in Grimsby UK.
11 years 4 months ago #1119 by magoo²
Replied by magoo² on topic 3rd station in Grimsby UK.
Moved the unit inside the house today. Think it may just be broken as used three different power supplies and the readings are sky high. Going to borrow another unit and see if i can track problem down with mine
The following user(s) said Thank You: tcall
11 years 4 months ago #1160 by tcall
Replied by tcall on topic 3rd station in Grimsby UK.
I have taken on Matt's Geiger Counter which started running a bit hot recently. I have found the same effect. After turning the voltage down and putting an extra 1.5Meg resistor in line with the tube, it still suddenly started
showing high readings. As a result, I have replaced it and am back on line. It is not yet showing on the graphs, but the readings are being correctly transmitted. Perhaps it will take a few days to get latched on to the system, since I have been off-line for a few weeks.
Time to create page: 0.121 seconds
Solar powered Raspberry Pi 4 server stats: CPU 50% Memory 15% Swap 18% CPU temp=65.7'C Uptime 17 Days
