Hi From Florence IT
10 years 10 months ago - 10 years 10 months ago #1483 by mw0uzo
Replied by mw0uzo on topic Hi From Florence IT
Yes its all done, use your username and the password you sent via PM in RadLog.
User and pass are case sensitive, let me know if you have any problems.
Last edit: 10 years 10 months ago by mw0uzo.
The following user(s) said Thank You: alexsgv
10 years 10 months ago #1487 by alexsgv
Replied by alexsgv on topic Hi From Florence IT
Yes, it works! thanks!
I've just a litle question about conversion factor.
Is there a conversion factor for the tube used inside my counter GMC-320+ V4 (Tube M4011) ?
thanks for your help
Alex
10 years 10 months ago #1508 by W8HF
Replied by W8HF on topic Hi From Florence IT
From the BASH script examples elsewhere on the forum.
conversionfactor="0.0081" ## GM tube conversion factor for J305 / M4011
10 years 10 months ago #1509 by W8HF
Or better yet this forum topic.
http://radmon.org/index.php/kunena/geiger-muller-tubes/43-conversion-factors
I just added a detector to my setup using that tube. The first night showed it slightly more sensitive than SB200. After I collect more data I may revise my settings. I'm adding counts from two separate counters with different tubes so the conversion is a combination of both.
Good luck.
Time to create page: 0.152 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 18% CPU temp=64.7'C Uptime 17 Days
