Hello from Saskatchewan!
10 years 10 months ago #1510
by fusebit
Hello from Saskatchewan! was created by fusebit
Hi,
I'm Dirk, currently living in Regina, Saskatchewan in Canada.
I've got a MyGeiger from RH Electronics with an LND-712 tube, which will be connected to the system first.
I also got a Mighthyohm kit running with an SBM-20. Currently setting up one of my Raspberry Pi to get that one going to be connected to this system. The link to the Python script on this website seems to be broken
Still got two SBM-20 and a LND-712, so I just started to build my own geiger counter...
KR
Dirk
KR
Dirk
10 years 10 months ago #1511
Replied by Juzzie on topic Hello from Saskatchewan!
Hi Dirk, Welcome!
Sounds like you fit in pretty well around here. What problem are you having downloading PyRadmon ?
I just tried to download and it worked fine....
10 years 10 months ago - 10 years 10 months ago #1513
by fusebit
Okay, I've got it!
The link under 'about' is broken, but the one under 'downloads' works fine.
Replied by fusebit on topic Hello from Saskatchewan!
Okay, I've got it!
Last edit: 10 years 10 months ago by fusebit.
10 years 10 months ago #1520
Replied by mw0uzo on topic Hello from Saskatchewan!
Hi fusebit, I'll get your radmon account sorted as soon as I can. Welcome!
Lots of preparation here to do today for some electrical work and tidying up after. With a little luck I can add you this evening..
10 years 5 months ago #1929
by fusebit
Hello mw0uzo,
could you please change my location to:
Hamburg, Germany
Thanks!
Hamburg, Germany
Thanks!
10 years 5 months ago #1930
Ok done!
Send some data and you should appear on the map.
You can adjust the position using RadLog on a Windows machine. Or look at the BASH scripts for changing it from the linux command line or browser.
