New Station near Linz / Austria
10 years 3 months ago #2208 by mw0uzo
Ok added :)
Welcome to radmon.org!
10 years 3 months ago #2215 by Johndoe
Thanks,
works great, I started reporting today at noon.
Was a bit of a challenge because some settings (position, conversation rate...) are only set able with a windows pc and radlog.
Is it possible to publish the data or download it again?
best regards
John
10 years 3 months ago #2228 by Frank
Oh ya, there you are, found you. You in experiment mode I see? symbol is dark green instead of bright green. Nice option to have when you doing trials, etc then go normal when done. You know your in experiment mode, correct? :)
10 years 3 months ago #2230 by Johndoe
I know that my station is in experimental mode, but I don't know how to switch from experimental to normal mode.
I will have to ask around, but I think this has to be done by an admin of radmon.org
10 years 3 months ago - 10 years 3 months ago #2231 by Frank
Check the RadMon Tab in the program, right below your Password, make sure there is a check mark there, if not, it shows up on the map as experiment mode. Let me know if this was it. :)
Last edit: 10 years 3 months ago by Frank. Reason: typo
10 years 3 months ago #2233 by Frank
Your bright green now! :) Normal mode.
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 14% Swap 18% CPU temp=64.7'C Uptime 17 Days
