New station (Spingse)
10 years 2 months ago #2326 by VePink
New station (Spingse) was created by VePink
Hello everyone!
My name is Vejas, I'm from Lithuania.
I am converting an old analog geiger counter RKSB-104 into radiation monitoring station. I'm planing to use Arduino UNO and Ethernet Shield to connect this sistem to RadMon.
Currenly I am able to display geiger counter's CPM values to PC screen using Arduino's Serial print. I've also tried loging CPM values.
Now I want to step further and set up online connection to RadMon.
For now I'm giving You short information about my station:
Location: Lithuania, Vilnius, (54°40'57.44" N; 25°15'18.15" E);
Model: RKSB-104 and ArduinoUNO homemade hybrid;
The type of detector tube: SBM-20U;
Other info: It's an outdoor detector;
Station SPINGSE:
RKSB-104 + ArduinoUno
The following user(s) said Thank You: Fenton112
10 years 2 months ago - 10 years 2 months ago #2328 by Simomax
Replied by Simomax on topic New station (Spingse)
You shouldn't need More than the Arduino you are currently using (i.e. ethernet shield not needed). The Radlog software supports RS232 directly. That is, provided your Arduino can print the CPM + newline for each submission. So, if you are seeing (in a terminal) just the CPM count on a new line each time it is sent from the Arduino you should be good to go. Just select 'Kit with USB/TTL serial interface' in the Radlog software.
Oh, welcome btw! :) Dan should get your login sorted soon.
Last edit: 10 years 2 months ago by Simomax.
The following user(s) said Thank You: mw0uzo, VePink
10 years 2 months ago #2331 by VePink
Replied by VePink on topic New station (Spingse)
Simomax, I would like to have 24/7 working autonomiuos station without need to keep my laptop always connected to it. That's why I need set up with ETH shield.
Station SPINGSE:
10 years 2 months ago #2337 by Frank
Replied by Frank on topic New station (Spingse)
Welcome to the site and group VePink :)
10 years 2 months ago #2353 by VePink
Hi.
I'm still waiting for registration...
Maybe someone can describe workflow how to publish data to RadMon site using Arduino ethernet shield? I've tried using code snippets from this page. No success. Maybe someone alredy has ready to work arduino etehernet shield code?
Now I'm only able to log CPM values to radmon desktop app.
Station SPINGSE:
10 years 2 months ago - 10 years 2 months ago #2365 by mw0uzo
Replied by mw0uzo on topic New station (Spingse)
Welcome to radmon.org! :cheer:
Its all set up. Thanks for waiting!
Last edit: 10 years 2 months ago by mw0uzo.
The following user(s) said Thank You: VePink
Time to create page: 0.310 seconds
Solar powered Raspberry Pi 4 server stats: CPU 54% Memory 15% Swap 17% CPU temp=64.7'C Uptime 17 Days
