An old station in Careywood Idaho
10 years 1 month ago #2414 by FarmerDave
Hi, I have been sending date to Geiger Counter Word Map for the past six years and just noticed this site. If all goes well I will see if I can also post it here.
10 years 1 month ago - 10 years 1 month ago #2415 by Bert490
Welcome, FarmerDave. The GQ detectors work here either through USB audio or USB data. Once the readings are getting to the Radlog software, use the password that will be given to you by the admin to get the values onto the map.
Correction for any subsequent readers: .. either through audio (USB audio or MIC input) or USB data.
Last edit: 10 years 1 month ago by Bert490.
The following user(s) said Thank You: FarmerDave
10 years 1 month ago #2417 by Fenton112
Cool man, I've seen that site before. Welcome
10 years 1 month ago - 10 years 1 month ago #2420 by mw0uzo
Welcome FarmerDave!
I will add you to the system now. Check your PMs for the password.
You need to enter the username FarmerDave and the password I give you into RadLog.
Last edit: 10 years 1 month ago by mw0uzo.
Time to create page: 0.142 seconds
Solar powered Raspberry Pi 4 server stats: CPU 63% Memory 14% Swap 17% CPU temp=61.8'C Uptime 17 Days
