Hi from Poland.
9 years 10 months ago #2643 by Rosomack
Hi from Poland. was created by Rosomack
Hi. I'm Paweł, from Świebodzin.
I'm using a Radiatex MRD-2 geiger counter with a STS-5 tube, I don't have any other device at the moment, but maybe I'll have another counter with an outdoor detector. But we'll see.
Radiatex MRD-2 + DP-66M
9 years 10 months ago #2644 by Martinov
Replied by Martinov on topic Hi from Poland.
Hi, Pawel! :)
9 years 10 months ago #2647 by mw0uzo
Replied by mw0uzo on topic Hi from Poland.
Ok it's all done! Welcome to radmon.org! :)
The following user(s) said Thank You: Rosomack
9 years 10 months ago #2650 by Rosomack
Replied by Rosomack on topic Hi from Poland.
Thanks! I see my counter is online. Nice!
9 years 10 months ago #2652 by Bert490
Replied by Bert490 on topic Hi from Poland.
Welcome, Pawel
Your detector is showing good data values. When you are finished testing, don't forget to take it out of experiment mode so that alarms will become active.
9 years 10 months ago - 9 years 10 months ago #2654 by Rosomack
Yes, I saw that. I need to make a power supply for the detector, it was running on a battery the whole time. Also I need to find a better place to locate it in my house, so it won't be interrupted with some of my radiation experiments. Anyway, good it's sending the right data.
Edit:
I don't want to make a new topic for this. I decided to use my old netbook (hp compaq mini 110c) for a station. I need to replace the fan, because it's broken, format the disc and install RadLog. Then I need to find an 9V power adapter for the Radiatex and put it all together in some "stable" place in my house and let it run and send data. I hope the software will work on that machine.
Last edit: 9 years 10 months ago by Rosomack.
Time to create page: 0.168 seconds
Solar powered Raspberry Pi 4 server stats: CPU 61% Memory 14% Swap 17% CPU temp=62.8'C Uptime 17 Days
