Greetings from Austria
9 years 7 months ago #2816 by oe3gwu
Hy!
My Name is Rainer. I am a HAM Radio Operator since almost 10 Years now. I am Sysop on the Nebelstein Repeater Site and very active in Digital Stuff in HF / VHF and UHF, including APRS.
I want to transfer Data from my Geiger Counter to your account, and also to APRS.
There I got a question. Is RadMon and APRS Linked? How can those Infos be forwarded? I was told that this works somehow. I use pyradmon.
My Geigercounter is a GMC-320 - with the Standard Tube inside currently.
Thanks
Rainer (OE3GWU)
9 years 7 months ago #2841 by mw0uzo
Replied by mw0uzo on topic Greetings from Austria
Welcome Rainer!
I will add you to the system now.
To upload your data to APRS system via the web, use RadLog.
I have a problem with the APRS modulator in RadLog, I wonder if you can help? I am trying to find a way to inspect the raw bits in a packet. I can see them when using SoundModem and the GUI, but I can't save or dump to a file before the bits disappear off the screen!!
I have an error in the modulator which is causing generated APRS packets to be rejected. I think its just the data encapsulation, CRC etc seems to be correct.
9 years 7 months ago #2842 by mw0uzo
Ok its all set up!
9 years 7 months ago - 9 years 7 months ago #2853 by oe3gwu
Replied by oe3gwu on topic Greetings from Austria
Hy!
I dont know your software very well currently, therefore I have some questions.
APRS Modulator. Does that mean that you send APRS Packets via a TNC to the VHF APRS Network? If so, please bare in mind, that you need 200 - 300ms of "preamble" where the system is keyed but no data is transmitted. When updating the Data through Internet (APRS-IS), does it work, or do you have the same issues there?
Here is a RAW Packet Log from the APRS-IS Network:
http://aprs.fi/?c=raw&call=KI6TSF-8
I am happy to help you. Though I cant use the 0.42 Version because of an Issue I wrote you earlier last week. So I cannot help much without a solution to this.
Last edit: 9 years 7 months ago by oe3gwu.
Time to create page: 0.132 seconds
Solar powered Raspberry Pi 4 server stats: CPU 66% Memory 14% Swap 18% CPU temp=64.2'C Uptime 17 Days
