Hi from England
9 years 5 months ago - 9 years 5 months ago #3101 by mickr
Hi from England was created by mickr
Hello everyone mickr here.
I live in the UK and thought I'd build a couple of Geiger counters after recently reading about Fukushima.
The one I'm going to be using for this site is built on veroboard, and uses a nodeMCU esp8266 clone from ebay.
I used the code from GKRadmons kit, although I've modified it to include support for a BME280 temp / humidity / pressure sensor using the Adafruit BME280 library.
I'm also using a CTC-5 tube.
Last edit: 9 years 5 months ago by mickr.
9 years 5 months ago #3104 by Simomax
Replied by Simomax on topic Hi from England
Welcome mickr.
What part of England are you in? I'm over in Blackpool and it's great to see more people in the UK.
9 years 5 months ago #3105 by mickr
Replied by mickr on topic Hi from England
Opposite side of the country, Durham. Although I've been over your way a few times :)
9 years 5 months ago #3111 by Simomax
Sweet. Will be great to see your station on the map as there are none over youir way. I'm sure Dan will getr you a login set up soon :)
9 years 5 months ago #3121 by mw0uzo
Replied by mw0uzo on topic Hi from England
Great project and welcome! :) I'll get you set up now.
9 years 5 months ago #3123 by mw0uzo
It's done, check your PMs for the password
The following user(s) said Thank You: mickr
Solar powered Raspberry Pi 4 server stats: CPU 57% Memory 15% Swap 18% CPU temp=63.7'C Uptime 17 Days
