Greetings from Colorado
  • b51born
  • b51born's Avatar Topic Author
  • Visitor
  • Visitor
9 years 1 month ago #3413 by b51born
Greetings from Colorado was created by b51born
Greetings,
I have a GQ GMC 300e attached to a Raspberry pi 3, outside and under a covered porch, It is protected by an inverted plastic ballot box that allows the G/M tube exposure at the slot.
The coordinates in Golden, Colorado, USA are:
39.7907969, -105.1745856
I believe it is now transmitting using the PyRadmon program.
Thank you,
b51born
9 years 1 month ago #3414 by Bert490
Replied by Bert490 on topic Greetings from Colorado
Welcome!
It should work once you enter the password that will be provided to you by mw0uzo.
The following user(s) said Thank You: mw0uzo, b51born
9 years 1 month ago #3419 by mw0uzo
Replied by mw0uzo on topic Greetings from Colorado
Welcome to radmon.org! B)
It's all set up with with password you requested.
The following user(s) said Thank You: b51born
Time to create page: 0.178 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 15% Swap 17% CPU temp=65.7'C Uptime 17 Days
