New GMC-500 in Napa, CA USA
9 years 1 week ago #3558
by Adrian
New GMC-500 in Napa, CA USA was created by Adrian
Looking forward to getting beyond the "unhandled exception errors" in windows 10.
Not sure what interface to select, I'm using USB cable supplied.
The GQ-GMC data monitor and world map does work but is sooo limited.
Regards, Adrian
Regards, Adrian
9 years 1 week ago #3559
Replied by Bert490 on topic New GMC-500 in Napa, CA USA
Note that applications cannot share computer ports, so if you are still running the GC maps application, the USB port is occupied. The 2 possibilities are:
1. Disable or uninstall the GC maps app (not a difficult decision IMHO), and configure Radlog to use the USB port (use the stable Radlog version 0.41).
2. Connect a second computer port such as an audio microphone to your detector's audio output (hopefully it has one). In this case, Radlog is configured for audio input. Then the detector can feed 2 maps. I feed Radmon and Netc myself. I agree with you on the limitations of the GC world map.
9 years 6 days ago #3563
Replied by mw0uzo on topic New GMC-500 in Napa, CA USA
Yes, use the stable version, there are some initialisation bugs in the development one.
Get it working with the stable, then maybe try the development once you're familiar with the settings.
9 years 6 days ago #3564
Ok your account is set up. Check your PMs for the password
The following user(s) said Thank You: Adrian
Time to create page: 0.129 seconds
