Hello from Switzerland
8 years 7 months ago - 8 years 7 months ago #3850
by pylon
Hello from Switzerland was created by pylon
Philipp from Holzmannshaus, TG, Switzerland (47.474295, 8.969495)
GK Radmon Plus Kit
sends data to MQTT server, a patched version of pyradmon gets it from there
Tube: SI 180G
Indoor detector currently, plans to move it outdoor.
I have 3 nuclear power plants inside a 100km radius around my house. I already owned a GK-Plus counter but got a GK Radmon Plus Kit recently because I planned to install a constantly reporting sensor outdoors.
The sensor is reporting to my in-house MQTT server. To post the data to your side I downloaded the pyradmon tool and added an MQTT driver to it (I had to port it to Python 3 to get that running). If anyone's interested, it's simple but works (tested only against my own server at the moment).
I would be happy to push the density of measurement stations in the center of Europe a little bit higher.
Edit: Added Coordinates
GK Radmon Plus Kit
Tube: SI 180G
Last edit: 8 years 7 months ago by pylon.
The following user(s) said Thank You: radmonch
8 years 7 months ago #3853
by zurich
Replied by zurich on topic Hello from Switzerland
Ein Willkommensgruss ins Thurgau vom Zürisee.
http://wetterstation.web4ever.ch/
8 years 6 months ago #3860
Replied by mw0uzo on topic Hello from Switzerland
Welcome to radmon.org!
Please check your PMs for the password.
8 years 6 months ago #3862
by pylon
Replied by pylon on topic Hello from Switzerland
Thank you, my station is already sending data. Seems to arrive successfully.
8 years 6 months ago #3904
by pylon
In the map I can see that my station has a conversion factor of 0.0057 configured. For the tube I use (SI180G) a conversion factor of 0.0031 is much more appropriate, otherwise the calculated µSv values are wrong. I guess a warning level of 100 and an alarm level of 200 CPM are also better values to not constantly enter my station into warning state.
May I ask you to change these values? Thank you!
8 years 6 months ago - 8 years 6 months ago #3907
Replied by Bert490 on topic Hello from Switzerland
Hello and welcome. Please check out the BASH scripts
>here<
so see how to change the various configuration parameters at the server.
Last edit: 8 years 6 months ago by Bert490.
Time to create page: 0.343 seconds
