New station
6 years 7 months ago #5022 by larkar
Replied by larkar on topic New station
Something you did reduced the readings to a normal level, what did you do?
6 years 7 months ago - 6 years 7 months ago #5027 by Alpha01
Replied by Alpha01 on topic New station
Hello zendick,
I suspect three things:
- A too long connection between the PCB and the tube. Make a direct, as short as possible connection, and see if it improves the behavior.
- A poor tube, that's happening sometime with NOS SBM20. If this is the case, nothing to do, put a new one... BUT, before attempting this exchange, see below...
- Wrong voltage: that's possible as the radmon plus kit doesn't really measure the voltage and lock on it, but only assumes it for a given duty cycle and associated components. Only one thing to do, really measure the voltage with a high impedance probe (> 100Mohms or better 1Gohms) - Remove the tube before and put the probe at the junction of R6 and R7, you should have around 400V for a SBM20. This should match the setting of the kit.
Another thing to take in account: check R7 for the correct value (4.7 megaohms), if you are not using an anode resistor, jumper "RL_JMP" must be open. Anyway, a resistor is mandatory in the anode line (R7 or the external one), if for any reason this resistor is missing or shorten, this could quickly destroy the tube...
Last edit: 6 years 7 months ago by Alpha01. Reason: Add details
Time to create page: 0.131 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 15% Swap 17% CPU temp=63.3'C Uptime 17 Days
