Forum
Geiger counter discussions
Kit geiger counters
GKnet
GKnet
Thank you received: 432
11 years 6 months ago #860
Are the GKnet stations still working? With the change in server location, the IP has also changed. I don't know if the ip is fixed in the firmware or if the full domain name is used.
Thank you received: 1
11 years 6 months ago #863
by WA0RTU
Had to do a reset the other day Dan. But I am still feeding via GKnet. My data is up to date.
Tom
Thank you received: 14
Thank you received: 31
7 years 1 month ago #4483
I finally tried the GKnet out. Sadly it doesn't appear to be uploading data. Counter is a Brohogan with version 11 software. I think I've done everything correctly.
7 years 1 month ago #4484
Check you have the radmon username set correct FSM19 and then leave the GKnet logging. I will check the logs to see what is received.
The following user(s) said Thank You:
FSM19
7 years 1 month ago - 7 years 1 month ago #4485
Thanks, At the moment I have one of my other setups running. It will take me a few minutes to switch over. Should be online from say 1500 BST. I've done a bit more checking, it looks like the GKnet board isn't receiving any data from the counter. I've re-flowed connections on both boards, but still no joy. Looks like I definitely have a hardware problem.
Last edit: 7 years 1 month ago by
FSM19.
Forum
Kit geiger counters
GKnet
Time to create page: 0.179 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 15% Swap 17% CPU temp=63.7'C Uptime 17 Days
