GKnet
11 years 6 months ago #860 by mw0uzo
GKnet was created by mw0uzo
Are the GKnet stations still working? With the change in server location, the IP has also changed. I don't know if the ip is fixed in the firmware or if the full domain name is used.
11 years 6 months ago #863 by WA0RTU
Replied by WA0RTU on topic GKnet
Had to do a reset the other day Dan. But I am still feeding via GKnet. My data is up to date.
Tom
11 years 2 days ago #1379 by BroHogan
Replied by BroHogan on topic GKnet
The domain name is used. Still chugging away.
John
7 years 1 month ago #4483 by FSM19
Replied by FSM19 on topic GKnet
I finally tried the GKnet out. Sadly it doesn't appear to be uploading data. Counter is a Brohogan with version 11 software. I think I've done everything correctly.
7 years 1 month ago #4484 by mw0uzo
Replied by mw0uzo on topic GKnet
Check you have the radmon username set correct FSM19 and then leave the GKnet logging. I will check the logs to see what is received.
7 years 1 month ago - 7 years 1 month ago #4485 by FSM19
Thanks, At the moment I have one of my other setups running. It will take me a few minutes to switch over. Should be online from say 1500 BST. I've done a bit more checking, it looks like the GKnet board isn't receiving any data from the counter. I've re-flowed connections on both boards, but still no joy. Looks like I definitely have a hardware problem.
Last edit: 7 years 1 month ago by FSM19.
Solar powered Raspberry Pi 4 server stats: CPU 58% Memory 15% Swap 17% CPU temp=63.3'C Uptime 17 Days
