New pocket geiger counter based on PIN diode
9 years 5 months ago - 9 years 5 months ago #3154 by jnissen
Interesting new kit. May be able to get it to communicate with the system here?
https://www.sparkfun.com/products/14209
Last edit: 9 years 5 months ago by jnissen.
The following user(s) said Thank You: nu3e
9 years 5 months ago #3155 by Simomax
this sensor has a simple pulsed output that can be used with any microcontroller.
Yes, this could be used with Radmon/Radlog. I'm not sure if you could feed the pulse output directly into an audio input on a PC or whether it would need some simple electronics to lower the level suitable for the PC audio input. I suspect the latter as the pulses are probably around 5v and the audio input is about 1v. It could also be connected to a microprocessor such as an arduino or RPi and then the readings sent to Radmon directly or via a PC.
Time to create page: 0.121 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 14% Swap 18% CPU temp=62.8'C Uptime 17 Days
