RadiaLog
10 years 7 months ago #1772 by ThibmoRozier
Replied by ThibmoRozier on topic RadiaLog
What? That's wierd.
Will re-upload the file now.
10 years 7 months ago - 10 years 7 months ago #1773 by Frank
Replied by Frank on topic RadiaLog
Ya, the other one came right in, 6.7megs in size, but the other one, soon as I clicked on it, "failed" download.
update, worked that time, just downloaded it.
Last edit: 10 years 7 months ago by Frank.
10 years 7 months ago #1774 by ThibmoRozier
Here should be the updated version: https://github.com/thibmo/RadiaLog/releases/download/0.5/RadiaLog_x86_0.5.zip
If it still doesn't work I will upload to here.
10 years 7 months ago #1775 by Frank
I went up where you had it above and re-clicked on it and it downloaded ok this time. Not sure after you said you were uploading it if you did and I happen to do it right after that but it worked. Have it now, looks nice. Tomorrow I will play around with it as I have to find my audio input and feed the detector into it. Frank :)
10 years 7 months ago #1776 by ThibmoRozier
I think it was just a hiccup by Github. :)
10 years 7 months ago #1777 by Frank
Must have been, so, on my Win 7 pc, where I have radmon running, I shut that down and tried your program. Is this program similar to the one I had been running before, your other, older one? I put in the comm port that Radlog was using and the same baud rate, etc but only got 0's. I realize this is focused on the audio portion of receiving the signal but figured I give the serial side a try.
Time to create page: 0.154 seconds
Solar powered Raspberry Pi 4 server stats: CPU 62% Memory 15% Swap 18% CPU temp=64.2'C Uptime 17 Days
