radmon.org CPM reading posted to APRS
9 years 4 months ago #3233 by PA3GET
Dear community.
I made a script which will upload your CPM reading from the radmon.org website and post it to APRS.fi using a Raspberry Pi.
For an example reading look at the following link:
https://aprs.fi/#!call=a%2FPA3GET-10
53°12.24' N 6°33.92' E
2017-05-10 13:24:11 - 2017-05-10 16:52:56
radmon.org radiation monitor using GQ GMC-320plus V4.22 with M4011 β/γ tube. Last reading: 24 CPM on 2017-05-10 14:31:53UTC at Groningen, Netherlands
If interested I will post the script at this forum.
Kind regards,
73 Gert de PA3GET
The following user(s) said Thank You: mw0uzo, Gamma-Man, Onions
9 years 4 months ago - 9 years 4 months ago #3234 by OM1AMJ
Hi.
It would be better to shorten the comment text ;)
Not all (radio) devices are able to show text longer than recommended 43 characters (36 if packet contains data extension).
See APRS specification (chapter 8.): http://www.aprs.org/doc/APRS101.PDF
Also 1 minute interval for fixed station is not good idea.
If you have TX iGate (or more iGates) near you, all packets are also sent over the radio, and may cause overload.
For example, I use a 5 minute interval (low APRS activity around my QTH), and send an average CPM for 5 minutes.
I send the packets as an APRS object https://aprs.fi/info/a/GEIGER-PK
And WX (only temperature) I send with interval 15 minutes https://aprs.fi/info/a/OM1AMJ-6
Juraj/OM1AMJ
Last edit: 9 years 4 months ago by OM1AMJ.
The following user(s) said Thank You: PA3GET
8 years 10 months ago #3618 by OM1AMJ
I made change sending radiation to APRS.
Now I'm sending radiation as a WX station telemetry.
Position & temperature - 15 minute interval, radiation telemetry - 5minute interval.
https://aprs.fi/info/?call=OM1AMJ-6
https://aprs.fi/telemetry/a/OM1AMJ-6
Time to create page: 0.378 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 16% Swap 17% CPU temp=64.2'C Uptime 17 Days
