pyradmon feature request
11 years 8 months ago #508 by ThibmoRozier
Indeed, and it is under the development section due to testing phase. :)
11 years 8 months ago #509 by Juzzie
Replied by Juzzie on topic pyradmon feature request
got it.
11 years 8 months ago #514 by Frank
Replied by Frank on topic pyradmon feature request
Interesting, got it, thanks
11 years 5 months ago #921 by Marc
Replied by Marc on topic pyradmon feature request
I plug out my Geiger counter and plug it in. Its now on USB1 instead of USB0 and pyradmon stops working.
Need to fix this.
Create a file called geiger.rules in /etc/udev/rules.d
Add the line SUBSYSTEM=="tty", ATTRS{idVendor}=="067b", ATTRS{idProduct}=="2303", SYMLINK+="geiger"
to the file if its a GQ electronics GMC 320 but other data if its another counter. (There are ways to get the data.)
After reboot a device called @geiger will be created in /dev
Edit the pyradmon config.txt and set the serial port to /dev/geiger
Now pyradmon will always connect to the counter whatever USB port it is on.
Now this is a feature request, remember?
Marc PC1MH
11 years 3 months ago #1167 by dolphin
Replied by dolphin on topic pyradmon feature request
Thank you, Marc! I just added it to my computer, works like a charm, fixes the problem of more than one ttyUSB device attached (so they go up on different numbers after reboots).
Easy to get by doing a dmesg command in a command line, after attaching a new USB device. Device's IDs will be shown there.
11 years 3 months ago - 11 years 3 months ago #1191 by ThibmoRozier
Will look into it asap. :)
First, *Good news everybody~!*
The code has gotten a little cosmetic make-over and now has logging. :P
The log will be in the same directory as the code and the config file. :)
For now it is only "PyRadmon with audio", the others will follow after a short moment of testing. :)
At this moment your first running log should look along the lines of:
22/05/2015 20:47:50 PM - PyRadmon (Audio) - INFO - --------------------------------------- EOL ---------------------------------------
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Reading configuration
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - User name configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Password configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Serial port name configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Serial port speed configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Protocol configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Device number configured
22/05/2015 20:47:53 PM - PyRadmon (Audio) - INFO - Using DEMO protocol for 1 => geiger 1
22/05/2015 20:48:03 PM - PyRadmon (Audio) - INFO - Connecting to server => geiger 1
22/05/2015 20:48:04 PM - PyRadmon (Audio) - INFO - Server response => geiger 1: HTTP/1.1 200 OK
22/05/2015 20:48:34 PM - PyRadmon (Audio) - INFO - Connecting to server => geiger 1
22/05/2015 20:48:35 PM - PyRadmon (Audio) - INFO - Server response => geiger 1: HTTP/1.1 200 OK
22/05/2015 20:48:37 PM - PyRadmon (Audio) - ERROR - CTRL+C pressed, exiting program:
Traceback (most recent call last):
  File "C:\Users\Thimo\Desktop\python\Source\pyradmon-reborn-code\PyRadmon\PyRadmon.py", line 758, in main
    time.sleep(0.5)
KeyboardInterrupt
22/05/2015 20:48:37 PM - PyRadmon (Audio) - WARNING - Waiting and reap threads
22/05/2015 20:48:38 PM - PyRadmon (Audio) - INFO - Stopping alive thread: baseGeigerCommunication
22/05/2015 20:48:39 PM - PyRadmon (Audio) - INFO - Shutting down application *Bye-bye*
22/05/2015 20:48:39 PM - PyRadmon (Audio) - INFO - --------------------------------------- EOL ---------------------------------------
Last edit: 11 years 3 months ago by ThibmoRozier.
Time to create page: 0.172 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 13% Swap 17% CPU temp=63.7'C Uptime 17 Days
