Audio support for PyRadmon
- ThibmoRozier
11 years 10 months ago - 11 years 9 months ago #151
by ThibmoRozier
Audio support for PyRadmon was created by ThibmoRozier
This topic will handle the addition of audio within PyRadmon.
Project moved to SourceForge!
SourceForge project page: PyRadmon Reborn
I will be using either PyAudio for this script.
Installation:
1> Use your package manager to install PortAudio. ( http://www.portaudio.com/ )
2> Install PyAudio ( http://people.csail.mit.edu/hubert/pyaudio )
3> Run PyRadmon.py once (python ./pyradmon.py)
4> Configure all the settings in config.txt
5> Run PyRadmon.py again and monitor.
Download:
Single counter:
Two counters:
Other:
Fully functional now, a great shout-out to Dan for initial help and hints.
Thanks to PyAudio, Python and Russell Borogove @ Stack Overflow for the library's and good passive help.
Installation:
Download:
Single counter:
Two counters:
Other:
Last edit: 11 years 9 months ago by ThibmoRozier.
11 years 10 months ago #152
Replied by mw0uzo on topic Audio support for PyRadmon
I can help.
When I run the script for the first time I get
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Daniel>cd Desktop
C:\Users\Daniel\Desktop>MultiPyRadmon.py
File "C:\Users\Daniel\Desktop\MultiPyRadmon.py", line 826
for n in range(0, n < bytesrecorded; n = n + 2):
SyntaxError: invalid syntax
C:\Users\Daniel\Desktop>Please Log in or Create an account to join the conversation.
11 years 10 months ago #153
'deadticker' needs to be initialised to 1 or pulse detection won't work properly
- ThibmoRozier
11 years 10 months ago #154
by ThibmoRozier
- ThibmoRozier
11 years 10 months ago #155
by ThibmoRozier
Replied by ThibmoRozier on topic Audio support for PyRadmon
-Deep zen sigh- Soo, basically I am stuck on this:
I fixed all other tinyminy issues. ^_^
Forgot to format some C# parts to python before.
Updated file is up now, helpies? Q.Q
Problem with audio port => geiger 1:
'float' object is not iterable
Exiting
- ThibmoRozier
11 years 10 months ago #156
by ThibmoRozier
So, basically I need a helping hand on this total confusion of a logic....
(No idea who made it up but it got me and a math freak brain-fart.
Problem section:
Problem section:
self.amplitudebuffer=None
self.envelope = float(0)
self.detectwidthcounter = 0
self.lastrisingedge = float(0)
self.lastfallingedge = float(0)
self.lastdeadtimeedge = float(0)
self.lastminwidthedge = float(0)
self.last = False
self.onecaptured = False
self.deadticker = 1
cpm=25
stream = self.p.open(format=self.FORMAT, channels=self.CHANNELS, rate=self.RATE, input=True, frames_per_buffer=self.CHUNK)
frames = []
for i in range(0, int(self.RATE / self.CHUNK * self.RECORD_SECONDS)):
dataAudio = stream.read(self.CHUNK)
frames.append(dataAudio)
try:
bytesrecorded = self.CHUNK * self.RECORD_SECONDS
sampletime = float(float(1.0) / float(self.RATE))
detectlevel = float(0.025)
minwidth = int(math.fsum((float(5) / float(1000)) / sampletime))
deadtime = int(math.fsum((float(5) / float(1000)) / sampletime))
radcount = 0
self.lastrisingedge = -1
self.lastfallingedge = -1
self.lastdeadtimeedge = -1
self.lastminwidthedge = -1
arrayptr = 0
value = 0.0
attack = 0.001
release = 0.004
ga = math.exp(-1 / (self.RATE * attack))
gr = math.exp(-1 / (self.RATE * release))
svalue=0
for n in range(0, bytesrecorded):
# get your data into 'input'
svalue = (frames[n + 1] < 8) or frames[n] # Used to be svalue = (short)((e.Buffer[n + 1] << 8) | e.Buffer[n]);
if svalue == (-32768):
svalue = (-32767)
if svalue > 0:
value = math.fabs(svalue) / float(32767)
if svalue < 0:
value = math.fabs(svalue) / float(32768)
if self.envelope < value:
self.envelope *= ga
self.envelope += (1.0 - ga) * value
else:
self.envelope *= gr
self.envelope += (1.0 - gr) * value
self.amplitudebuffer[arrayptr] = math.floor(self.envelope)
if self.amplitudebuffer[arrayptr] >= detectlevel:
if self.detectwidthcounter == 0:
self.lastrisingedge = arrayptr * sampletime
self.detectwidthcounter = self.detectwidthcounter + 1
if self.detectwidthcounter >= minwidth:
radcount = radcount + 1
self.onecaptured = True
self.lastminwidthedge = arrayptr * sampletime
self.last = True
else:
if self.last==True:
self.lastfallingedge = arrayptr * sampletime
self.deadticker = deadtime
self.deadticker = self.deadticker - 1
self.last = False
if self.deadticker == 0:
self.lastdeadtimeedge = arrayptr * sampletime
arrayptr = arrayptr + 1
n = n + 2
cpm = radcount
except Exception as ex:
print "Problem with audio port => geiger 1:\r\n\t", str(ex),"\r\nExiting\r\n"
stream.stop_stream()
stream.close()
self.p.terminate()
self.stop()
sys.exit(1)
...Please Log in or Create an account to join the conversation.
Time to create page: 0.206 seconds
