Audio support for PyRadmon
11 years 9 months ago #228 by ThibmoRozier
Haven't heard anything yet.
Is it better now?
Or would I also need to make data dispose methods for the other stuff? Making it run more stable...
11 years 9 months ago #229 by mw0uzo
Replied by mw0uzo on topic Audio support for PyRadmon
I'll check it tomorrow. Getting the new versions onto the download page is on the list. Can you give me two links for the 'stable' and 'development' pyradmon? Then you can update as you see fit. :)
11 years 9 months ago #233 by ThibmoRozier
Yep, made a SourceForge page.
You can find it here.
https://sourceforge.net/projects/pyradmon-reborn
11 years 9 months ago - 11 years 9 months ago #235 by mw0uzo
Ah, great. :)
To get the CPMs in audio mode to look sensible, I had to change line 520 to
cpm = self.noisycount * ( 60 / 10 )
I haven't checked if this is correct and gives the same results against RadLog, but will as a final check that its working right.
To avoid 'numerical noise' I think the audio routine should count over 30 or 60 seconds, rather than 10. Perhaps three samples of 30 seconds with the fourth 30s period reserved for data sending?
I'm not sure if this is a problem or just a conincidence - the first audio counting period seemed to count extra pulses, but then settled down on the next one. I'll take a look at that again.
Last edit: 11 years 9 months ago by mw0uzo.
The following user(s) said Thank You: ThibmoRozier
11 years 9 months ago #237 by mw0uzo
Ok its been running well here, no significant mem usage or leaks, or crashes :cheer:
Has the source been updated with the CPM fix?
If so, I will update the download page.
11 years 9 months ago #238 by ThibmoRozier
I am on it. :)
Should be done today.
Maybe with audio source select.
Time to create page: 0.583 seconds
Solar powered Raspberry Pi 4 server stats: CPU 59% Memory 16% Swap 18% CPU temp=67.6'C Uptime 17 Days
