Zero CPM readings [Solution]
11 years 7 months ago - 11 years 7 months ago #572 by James_Gy
Hi,
I have noticed a few stations reporting 0CPM. I had this problem with my station but I accidentally found it was having too many temporary files that was causing it to happen. When I ran CCleaner it found almost 600MB of temporary files that radlog had generated but after clearing the temporary files the 0CPM reports have stopped.
Hope this helps,
James.
Last edit: 11 years 7 months ago by James_Gy.
11 years 7 months ago #573 by mw0uzo
Replied by mw0uzo on topic Zero CPM readings [Solution]
Interesting report, I will check for why this would be. Do you have a note of the file path where they were found?
11 years 7 months ago #574 by James_Gy
The files were located in C:\Documents and Settings\James\Local Settings\Temporary Internet Files\Content.IE5\ on my XP laptop.
Time to create page: 0.131 seconds
Solar powered Raspberry Pi 4 server stats: CPU 51% Memory 15% Swap 17% CPU temp=63.7'C Uptime 17 Days
