Help needed
6 years 4 months ago #5659
by MARK_A
Help needed was created by MARK_A
Hi everyone. After being away from this site for a bit (ok, like 3 years) I am trying to get my geiger output connected back to radmon. I've logged into Radmon.org successfully, but when I try to update my data I get the following error:
Warning
Profile could not be saved: Username does not meet the criteria:
May contain upper-case letters
May contain lower-case letters
May contain numbers
Min length: 3
Max length: 25
I am trying to update address, data login password, address, etc. Is my username not longer valid because it contains a '_' or is it something else. Can this be fixed or should I just create a new username?
Thanks in advance for the assistance
-mark
Warning
May contain numbers
Min length: 3
Max length: 25
-mark
6 years 4 months ago #5660
Replied by FSM19 on topic Help needed
I've sent a private message, but suggest you message mw0uzo, you're station doesn't show as active, so probably he needs to do something.
6 years 4 months ago - 6 years 4 months ago #5661
Replied by mw0uzo on topic Help needed
Hey MARK_A
Yes it's the underscore stopping things from working.
I have relaxed the restrictions so - and _ are allowed. Please try again to see if it works.
Thanks for being patient, i'm away and having stability problems with the server too.
Last edit: 6 years 4 months ago by mw0uzo.
Time to create page: 0.143 seconds
