RadLog v0.42 restart
11 years 4 months ago #1164 by mw0uzo
Replied by mw0uzo on topic RadLog v0.42 restart
Ok. When audio method is selected and logging started, the process priority is set to High. It returns to Normal when logging is stopped.
11 years 2 weeks ago #1359 by VE7CUP
Replied by VE7CUP on topic RadLog v0.42 restart
Any update on this ? Tnx, VE7CUP
11 years 1 week ago #1365 by mw0uzo
I'm going to release an alpha version, as there have been so many added features. This means there will be some untested and non-functional parts, but it will at least get some movement going on the release.
10 years 11 months ago - 10 years 11 months ago #1423 by Frank
Replied by Frank on topic RadLog v0.42 restart
Hi Dan, still out here. Had more projects going on but always made sure my station was up and running daily and live graph screen on my other PC. Looks pretty good out there, still have a good amount of members onboard. Was just checking in to see if version .42 was out yet or any news on it. I see a good handful of new members have joined from around the world. Glad to see the interest is still out there for you. So, reading above, how is .42 coming along, need any testing done? Getting ready for fall and winter here. Frank
Last edit: 10 years 11 months ago by Frank. Reason: typo's
10 years 11 months ago - 10 years 11 months ago #1426 by mw0uzo
Hey Frank :)
I have to finish sanding a floor in the house, then I will be spending some time on RadLog and radmon.org development. The plan is to tidy up the rough edges on RadLog for an alpha release (add SFTP, extra graph uploads, time sync and conincident stuff tidyup). Development has been stalled for a while due to personal commitments, these are clearing a little so some time can be allocated to radmon.org. Thanks for bearing with me!!!
I'm also hoping with the alpha release, the APRS packet modulator bug may be found... If anyone can work soundmodem on Linux and capture the raw bitstream generated on RX, then your help would be very much appreciated. I suspect the error will either be in CRC generation or packet format.
Right, off to sand some floor.. :angry:
Last edit: 10 years 11 months ago by mw0uzo.
10 years 7 months ago #1852 by mw0uzo
- NTP time syncro added for coincidence detection
Time to create page: 0.245 seconds
Solar powered Raspberry Pi 4 server stats: CPU 60% Memory 17% Swap 17% CPU temp=66.2'C Uptime 17 Days
