Problem with RDP to view RadLog
10 years 10 months ago #1442
by Gamma-Man
Problem with RDP to view RadLog was created by Gamma-Man
I have recently installed Radlog pro on a small PC with Windows 7 Pro.
Since I do not want another computer with monitor and kbd/mouse my plan was connecting with RDP (Remote Desktop Connection) from my workstation.
This works but when switching to RadLog I see that the readings goes from whatever it is at that moment and down to zero, and this goes for the graphs as well, all in a few seconds.
Not what I want.
Any hints should be appreciated
/Carl
Not what I want.
/Carl
10 years 10 months ago - 10 years 10 months ago #1445
Replied by mw0uzo on topic Problem with RDP to view RadLog
Hmmm, not sure about this one. Have you tried some different RDP settings? What exactly happens? Controls flickering all the time?
Last edit: 10 years 10 months ago by mw0uzo.
10 years 10 months ago - 10 years 10 months ago #1467
by Gamma-Man
Replied by Gamma-Man on topic Problem with RDP to view RadLog
Yes, but there is not so many settings in RDP. I have also tried e.g. Palantir, another remote desktop utility, with the same result.
After 10-20 seconds the reading goes down to zero, without any flickering on the screen.
The balloons on the map does however update as usual.
The graph on Graph tab goes down as well and the Audio pulse analyses on the Audi tab shows no movement.
If I click on the Start button in the lower right corner I get the message ”Audio logging already started”. If I the click on ”Stop” and then on ”Start” again I get the message ”Error starting recording: BadDeviceID calling waveInOpen”
If I then log out from the remote computer and log in at the local one where the RadLog program is running the readings is down to zero as well, but here I can stop and then start the reading again.
If I from the remote computer close the RadLog program and then start it again it do not automatically start the readings and if I manually click on "Start" I get the error message "Error starting audio recording: Objektreferensen har inte angetts till en instans av ett objekt." The last sentence is written in my native language swedish and Google Translate suggest this to be "Object reference not set to an instance of an object". This might indicate that this is a Windows problem because it is swedish Windows installations on both cumputers.
Carl
Carl
Last edit: 10 years 10 months ago by Gamma-Man.
10 years 10 months ago #1474
Looks like a mistake in the custom controls at the bottom of the window. It'll have to go onto the to-do list.
10 years 10 months ago #1486
by Gamma-Man
Thanks to Natrix in Storlien, Sweden it seems to work with TeamViewer version 9.
10 years 10 months ago #1488
Does anything flicker a lot in TeamViewer?
