RadLog v0.42 ALPHA
10 years 2 months ago #2247
by Yermo
Yes, im using the regular USB cable, with the USB Serial Lead. It is under Windows 10 x64... I will try with a different computer, and update.
Replied by Yermo on topic RadLog v0.42 ALPHA
Doesn't the GMC-320+V4 use a regular USB cable? Or are you using the audio output? I tried my 320 with the new program and it seemed to work fine. I had mine set to "GQ GMC USB Serial Lead." I'm not sure it will work if it is on the "kit" settings.
10 years 2 months ago #2375
by OldMule
I'm having the same problem, more or less.
One question first though: Is there a way to install this version without it automatically uninstalling the stable version so I can play with it without having to keep uninstalling/reinstalling them?
I'm running a GMC-300EPlus. Set normally, that is: COM3, Speed 57600, GQ GMC USB serial lead.
Running Windows 7 Home Premium 64-bit.
When I click the Start button on the program, it returns the following:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference not set to an instance of an object.
Then in the Details section it gives a whole bunch of stuff (ahem... prepare for spam... sorry! Devil's in the details, as the saying goes!
). Before I post that part though, I wanted to mention that part of it is showing a path that doesn't exist on my computer. The second line down there where it starts out "C:\Users\Daniel" etc. Could that be what's doing it, perhaps? It's referring to a path on the creator's computer (*looks at Dan and waves
*), so he won't be seeing the error on the computer he used to write it, if that's the cause.
I'm not the bugchaser I used to be, but the other thing that stood out for me was that it lists Win32 in the Details, so I tried it in compatibility mode. I tried XPsp3, VistaSP2, and 98/ME. XP and Vista compatibility had the same errors, and 98/ME (not unexpectedly) wouldn't run it at all.
Here's the full text of the details section (here's the spam I promised!
). I hope it might help!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at RadLogProfessional.RadLog.button1_Click(Object sender, EventArgs e) in C:\Users\Daniel\Documents\Visual Studio 2010\Projects\RadLog\RadLog\RadLog.cs:line 906
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.34209 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/OldMule/Geiger/Radmon%20Alpha/RadLog.exe
Win32 Version: 4.0.30319.34251 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.34270 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
Win32 Version: 4.0.30319.34238 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
NAudio
Assembly Version: 1.7.0.15
Win32 Version: 1.7.0.15
CodeBase: file:///C:/OldMule/Geiger/Radmon%20Alpha/NAudio.DLL
System.Windows.Forms.DataVisualization
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Win32 Version: 4.0.30319.34234 built by: FX452RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Replied by OldMule on topic RadLog v0.42 ALPHA
Tried to use it with a GMC-320+v4... but I cant because of the - Unhandled exception error. I had chosen the COM port and 'kit with USB/TTL serial interface'. Error details were "System.NullReferenceException.Object reference not set to an instance of an object" and a reference to Radlog.cs line 894.
mscorlib
System.Drawing
System
NAudio
System.Xml
Accessibility
enabled.
For example:
<configuration>
</configuration>
10 years 1 month ago #2457
by gw7eri
Replied by gw7eri on topic RadLog v0.42 ALPHA
Hi guys, Just for info, I've been trying v0.42A today, and am getting the same error: System.NullReferenceException.Object reference not set to an instance of an object"
The PC is a 'Mini Cyclone' running win10 and kit is the netio gc. Version 0.41 runs happily on this setup with the software installed on an 8gb stick.
Tried al sorts of different settings, but I cant I seem to get past that error code....
Best regards
Alex
GW7ERI
Best regards
Alex
GW7ERI
9 years 8 months ago #2754
by Nudnik
Replied by Nudnik on topic RadLog v0.42 ALPHA
Same error here
switching back to 0.41
9 years 7 months ago #2819
by oe3gwu
Replied by oe3gwu on topic RadLog v0.42 ALPHA
Same Error for me!
Informationen über das Aufrufen von JIT-Debuggen
anstelle dieses Dialogfelds finden Sie am Ende dieser Meldung.
************** Ausnahmetext **************
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
bei RadLogProfessional.RadLog.button1_Click(Object sender, EventArgs e) in C:\Users\Daniel\Documents\Visual Studio 2010\Projects\RadLog\RadLog\RadLog.cs:Zeile 894.
bei System.Windows.Forms.Control.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnClick(EventArgs e)
bei System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
bei System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ButtonBase.WndProc(Message& m)
bei System.Windows.Forms.Button.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 4.0.0.0.
Win32-Version: 4.6.1586.0 built by: NETFXREL2.
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
Assembly-Version: 1.0.0.0.
Win32-Version: 1.0.0.0.
CodeBase: file:///C:/Program%20Files%20(x86)/radmon.org/RadLog/RadLog.exe.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
NAudio
Assembly-Version: 1.7.0.15.
Win32-Version: 1.7.0.15.
CodeBase: file:///C:/Program%20Files%20(x86)/radmon.org/RadLog/NAudio.DLL.
Win32-Version: 4.6.1586.0.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization/v4.0_4.0.0.0__31bf3856ad364e35/System.Windows.Forms.DataVisualization.dll.
mscorlib.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
System.Windows.Forms.DataVisualization.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.DataVisualization.resources/v4.0_4.0.0.0_de_31bf3856ad364e35/System.Windows.Forms.DataVisualization.resources.dll.
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
System.Windows.Forms.resources
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht in diesem Dialogfeld behandelt.
mscorlib
System
System.Drawing
NAudio
mscorlib.resources
System.Core
System.Xml
Accessibility
Zum Beispiel:
<configuration>
</configuration>
9 years 7 months ago #2820
Replied by Frank on topic RadLog v0.42 ALPHA
Yup, I tried it when it first came out, was having all sorts of issues, ended up going back to .41 and flawless since.
Time to create page: 0.225 seconds
